P0140 code
P0140 code
Ive replaced my upstream o2 sensor to try and resolve this code coming up but it keeps coming back. Is this code also for the downstream sensor as well ? It says sensor 2..
- Archon
Re: P0140 code
Bank 1, sensor 2 is the O2 sensor after the cat.
Re: P0140 code
Thank you archon... Ill replace it. Ive noticed sounds like the cat is rattling when started in the mornings. I guess ill have to replace the cat as well..
- 98SSE
- Year and Trim: 2001 SSEI/2007 TBSS/2004 CTS-V
Re: P0140 code
Check to make sure its not the heat shield or something else rattling before you replace the cat. unless your wanting to in that case.
2001 Bonneville SSEI (His) - Gen V/3.5 pulley/CAI/SD Headers/ZZP 1.9 Rockers/90# Springs/Magnaflow Converter/HP Tuners/180* T-Stat/Trans-Go Shift Kit/TruCool Transmission Cooler/ F-Body Front Brakes/STS Rear Brakes/Tint/GXP Interior September 2015 COTM
2007 Trailblazer SS (Hers) - PCM4Less tune, E-Fans, SLP PowerFlo Exhaust, Hotchkis Sways, PML Tranny Pan, Powerstop Brakes,
"Big 3", Tint
2004 CTS-V (His) - B&B Exhaust, LS7 clutch, HIDs, LED fogs, Powerstop Brakes, Tint
"Big 3", Tint
