P0140 code
pfmeeks
Year and Trim: 2004 SE
P0140 code
Post by pfmeeks »
Ive replaced my upstream o2 sensor to try and resolve this code coming up but it keeps coming back. Is this code also for the downstream sensor as well ? It says sensor 2..
Archon
Re: P0140 code
Post by Archon »
Bank 1, sensor 2 is the O2 sensor after the cat.
pfmeeks
Re: P0140 code
Post by pfmeeks »
Thank you archon... Ill replace it. Ive noticed sounds like the cat is rattling when started in the mornings. I guess ill have to replace the cat as well..
98SSE
Year and Trim: 2001 SSEI/2007 TBSS/2004 CTS-V
Re: P0140 code
Post by 98SSE »
Check to make sure its not the heat shield or something else rattling before you replace the cat. unless your wanting to in that case.
2001 Bonneville SSEI (His) - Gen V/3.5 pulley/CAI/SD Headers/ZZP 1.9 Rockers/90# Springs/Magnaflow Converter/HP Tuners/180* T-Stat/Trans-Go Shift Kit/TruCool Transmission Cooler/ F-Body Front Brakes/STS Rear Brakes/Tint/GXP Interior September 2015 COTM
2007 Trailblazer SS (Hers) - PCM4Less tune, E-Fans, SLP PowerFlo Exhaust, Hotchkis Sways, PML Tranny Pan, Powerstop Brakes,
"Big 3", Tint
2004 CTS-V (His) - B&B Exhaust, LS7 clutch, HIDs, LED fogs, Powerstop Brakes, Tint
