My front passenger side window motor will activate and the window goes down. but the window motor will not activate and roll window up. it will not roll up from the drivers side button or the passenger side button. I am able to slide it up and into position using my hands on each side of the window glass. Its a talent I possess. What do you think? bad motor? or electrical? THANKS in advance for your responses.
Although I do not post much, I read the forum several times each week. Love the Bonnevilles. Keep up the good work.
window problem
kpopbonn
- Year and Trim: 2002 SLE - current
window problem
I'd rather have a bottle in front of me than a frontal lobotomy
1970 Grand Prix J - sold
1976 Grand Prix SJ - sold
1988 Bonneville SSE - sold
1995 Bonneville SSEi - totaled Oct 2014
2002 Bonneville SLE - bought Dec 2014
JohnR
- Year and Trim: 1997 Bonneville SE 40th Anniverary
Re: window problem
First step would be checking voltage at motor in both directions.
- MattStrike
- Year and Trim: '99 Montana
'04 Dirtymax
'97 Camaro
Re: window problem
Definately agree with the above recommendation. Some follow up:
Power at the motor but motor does not turn: Bad motor brushes, they can be replaced, or the motor can be replaced.
No power at the motor: Verify with a known working DS switch, one or both have partially failed
Boost addict
The Fleet:
'97 Camaro - Top swap
'05 STS - V8, AWD, her DD
'92 Trofeo - Fair weather DD
'99 Montana - top swap 3800
Current project:
Something cool, trust me.
Upcoming projects:
'92 Bonneville SSE
'87 LeSabre T-type
'67 LeSabre
Gone to greener pastures:
'97 LeSabre - Top swap
RIP:
'86 LeSabre - pictures
'93 SE - L67
The Fleet:
Current project:
Upcoming projects:
'92 Bonneville SSE
'87 LeSabre T-type
'67 LeSabre
RIP:
'93 SE - L67
kpopbonn
Re: window problem
THANKS for the responses. it will be a few days before I can take off the door panel to check it out.
mikeluscher159
- SSE Member
- Year and Trim: 2002 Bonneville SLE
Re: window problem
The fact that you can raise it by hand is concerning
When you try to raise the window, do you hear the motor click or try to move it up?
IIRC the passenger side switch is similar to the rears, try one of those at the passenger door and see if it changes anything
kpopbonn
Re: window problem
no the window motor does not click or make any noise when you push the button up.
the back windows work up and down.
