Can I use this unit or no? I hear that if the 4T65e unit doesn't have the webbing there it is suceptible to fracture. Need clarification here as I can be heavy footed at times and wouldn't want a broken case.
Transmission question for 2003 SSEi
rynmcdonald
- Posts like an LG3
- Year and Trim: 2003 Bonneville SSEi.
I recently visited the wrecking yard in search of an MN7 trans with FR2 ratio code. I DID find one, but it was in a Monte Carlo. Only problem is that it doesn't have the webbing that it's supposed to with SC engines. First I had my hopes up and wanted to get the unit, but after checking for the webbing my heart sunk and I was like
buickman104
- Posts like an LG3
- Year and Trim: N/A
Re: Transmission question for 2003 SSEi
You ABSOLUTELY need a transmission case with the webbing. The W bodies (mote carlo) don't need it because they lack a rear trans or engine mount.
rynmcdonald
- Posts like an LG3
So how then does a Monte Carlo support its transmission? Tension arms on the front of the engine? Wonder if I ise a chain and latch down my engine that way.
rynmcdonald
- Posts like an LG3
Wonder if I could put a 4T80e in this car and call it good after having the ECM tuned to the respective ratio of the transmission I get. 3.11:1 would be my choice.
2003 SSEi
- Year and Trim: 2003 SSEi.
LOTS of Mods
no the 80 is not a direct swap. While it would bolt up, you no need to make a brackets, and then have some one Tune it.
It would cost way more in the long run than to just get the correct 65
- nos4blood70
If only the 80 could swap in without any extra work... Yay for indestructo trans.
rynmcdonald
- Posts like an LG3
Why can't I just use the transmission out of the donor car that I have? It is a 2002 Grand Prix GTP. I know that the transmission will have a big pressure switch manifold but I am wondering if the computer can just swap over and it will work.
Did you miss the part about the W body Trans not have the webbing for the rear trans mount? The GTP does not have the structural webbing for the rear mount used on the H body..
The front of the H body does not have the support for the Dog Bones.. So I don't know what you would do there..
Spend a little now, or a lot later..
Maybe transfer the guts from one trans to another?
- nos4blood70
Consider this. They are the same internally, except for the casing. Luckily all L67s got the 2.93 gearing.Jrs3800 wrote: Maybe transfer the guts from one trans to another?
rynmcdonald
- Posts like an LG3
- crash93ssei
- Retired Moderator
- Year and Trim: 2002 SE
That was on a '96 - '99, different mounts to begin with. Though the 4T80E did come stock in the Bonneville GXP, this is still way more then you want to tackle especially for a stock or even mildly modded L67.
Find a trans for you car to just drop in and go or rebuild your current one.
- nos4blood70
The 4T80 also needs some computer work to operate properly.
rynmcdonald
- Posts like an LG3
My trans code is FR2. What are the drive and driven sprockets tooth count? I might be getting a code thrown because of this be cause one of the codes reads illegal range. I don't know what the heck that means.
