Restoring the SSEi: F40 swap, HIDs, and a HY35 turbo.
- MattStrike
- Year and Trim: '99 Montana
'04 Dirtymax
'97 Camaro
Re: Restoring the SSEi: F40 swap, HIDs, and a HY35 turbo.
I got the 150# springs for dirt cheap before I learned about race only springs and that's the reason they were cheap. I was originally looking for a 140# spring.
ST5 is a big cam, plus rockers, and turbo backpressure. I might get away with 130# if I didn't spin past 6k. ST5 makes power all the way to 6800.
Boost addict
The Fleet:
'97 Camaro - Top swap
'05 STS - V8, AWD, her DD
'92 Trofeo - Fair weather DD
'99 Montana - top swap 3800
Current project:
Something cool, trust me.
Upcoming projects:
'92 Bonneville SSE
'87 LeSabre T-type
'67 LeSabre
Gone to greener pastures:
'97 LeSabre - Top swap
RIP:
'86 LeSabre - pictures
'93 SE - L67
The Fleet:
Current project:
Upcoming projects:
'92 Bonneville SSE
'87 LeSabre T-type
'67 LeSabre
RIP:
'93 SE - L67
I am running the 105# Comp Cams springs. I only went to them after losing a motor due to a Crow spring breaking.
- radomirthegreat
- Year and Trim: 1994 SSEi 1999 SLE
But weren't people flocking to the Crow Cams springs because Comp Cams kept breaking? I recall Paul from PRJ Performance told me that the springs are fine, but they crack because they need more oil flowing under the valve covers to cool them. It's assumed that increasing the oil pressure in the engine helps keep any performance spring going longer.
94 SSEi - Project car
99 SLE - Tuned with different parts and such
85 Porsche 944 - Daily driver
68 Chevy C-10 - Free truck! Needs parts.
People went to crows because they were cheaper. There was a period where they had a bad run or something. After I broke a spring with 10k miles on it, I looked elsewhere. Have almost 30 on the Comps with OR rods and no issues at all.
- radomirthegreat
Well, all right then. I'm glad the cracking springs are over now!
- MattStrike
'04 Dirtymax
'97 Camaro
It looks like I found an energy suspension body mount that would work as a bushing for our subframes. I came across this site, which has measured each different body mount in each kit ES sells, they offer to sell them seperately: http://www.suspension.com/BODYMOUNT.html
Long story short, 3.4148, kit contains enough bushings to do two cars. Some grinding would need to be done to the subframe. The other benefit is it looks like these would also replace the hockey puck mounts I have with only minor trimming.
Boost addict
The Fleet:
Current project:
Upcoming projects:
'92 Bonneville SSE
'87 LeSabre T-type
'67 LeSabre
RIP:
'93 SE - L67
The Fleet:
Current project:
Upcoming projects:
'92 Bonneville SSE
'87 LeSabre T-type
'67 LeSabre
RIP:
'93 SE - L67
- MattStrike
'04 Dirtymax
'97 Camaro
So I'm seeing possibility that the pushrods I have are not 'strong enough' for my springs, but the only further upgrade is a 3/8" pushrod, which one vendor claims do not fit a 3800.
Comp makes a 5/16 pushrod with a 0.105 wall thickness, but it's not oil restricted.
Boost addict
The Fleet:
Current project:
Upcoming projects:
'92 Bonneville SSE
'87 LeSabre T-type
'67 LeSabre
RIP:
'93 SE - L67
The Fleet:
Current project:
Upcoming projects:
'92 Bonneville SSE
'87 LeSabre T-type
'67 LeSabre
RIP:
'93 SE - L67
Zeik75
- Posts like an L36
- Year and Trim: 1988 LE
2000 SSEi - Location: Lincoln, NE
Idk about series 2 but i think 3/8 would defiantly fit in the ln3, not sure if this helps. But i must question whats different about your setup that the pushrods would be a failure point? I assume people have ran your springs before without problem on higher hp builds.
-Austin-
Zeik75
- Posts like an L36
I can measure my spare heads when i get home tomorrow and let you know the bore and clearance.
-Austin-
- MattStrike
'04 Dirtymax
'97 Camaro
Intense says right on their pushrod page that springs over 130# would need the 3/8" pushrods (as well as setups over 20psi boost), while ZZP says that 3/8 pushrods don't fit.
And I don't want to have to pull everything apart again later for broken pushrods.
Boost addict
The Fleet:
Current project:
Upcoming projects:
'92 Bonneville SSE
'87 LeSabre T-type
'67 LeSabre
RIP:
'93 SE - L67
The Fleet:
Current project:
Upcoming projects:
'92 Bonneville SSE
'87 LeSabre T-type
'67 LeSabre
RIP:
'93 SE - L67
Zeik75
- Posts like an L36
I have a feeling they will fit fine, i don't think intense would suggest them if they didn't fit.
-Austin-
- yourgrandma
- Year and Trim: '02 SSEi
I don't see why they wouldn't fit. Did you pull the ones out that I sold you? Bent one? I don't remember who intense has make their pushrods. but maybe find out. Those. O83 walls should be pretty sturdy.
This reminds me, I really need to upgrade my pushrods. Still running the original yella terra units with 1.8 rockers and an s1x cam and 130# springs.
- MattStrike
'04 Dirtymax
'97 Camaro
What do you see wrong with this picture?
Boost addict
The Fleet:
Current project:
Upcoming projects:
'92 Bonneville SSE
'87 LeSabre T-type
'67 LeSabre
RIP:
'93 SE - L67
The Fleet:
Current project:
Upcoming projects:
'92 Bonneville SSE
'87 LeSabre T-type
'67 LeSabre
RIP:
'93 SE - L67
- 95naSTA
- Year and Trim: 95 SLE
Rocker arm bolts snapped? (assuming there's no hole in the fabric)
- Wes
- Posts like a Northstar
- Year and Trim: 2002 Buick Park Ave
The only thing I noticed at first is the slight color variation on the allen head in the front. Heat? or is this just a result of the flash?
And hard to tell from the angle in the pic, but is there a hole for the oil to pass through up by the push rod?
yourgrandma wrote:High
- MattStrike
'04 Dirtymax
'97 Camaro
Yes, they snapped right at the base of the pedestal. Not sure if I should get a stud kit now, or try the comp cams bolts. I was using alloy socket head cap screws, 170,000psi tensile strength.
Boost addict
The Fleet:
Current project:
Upcoming projects:
'92 Bonneville SSE
'87 LeSabre T-type
'67 LeSabre
RIP:
'93 SE - L67
The Fleet:
Current project:
Upcoming projects:
'92 Bonneville SSE
'87 LeSabre T-type
'67 LeSabre
RIP:
'93 SE - L67
- Jfridge92
Are those YT rockers Matt? What kind of spring pressures are those springs putting out under load? Only reason I ask is a lot of the LS guys with the YT rockers have a lot of trouble with the rockers and sometimes the bolts with springs that give 400lbs or more of open pressure. I'm not positive, but I believe the 3800 rockers and the LS rockers are the same design. Is it possible that you might be using too much spring for that style bolt?
Joseph
1999 Infiniti G20T - Sold
- MattStrike
'04 Dirtymax
'97 Camaro
It's entirely possible it's just too much spring, but it's also possible I over-torqued one of the bolts and it was already compromised.
I've put on the comp cams bolts now, we'll see how that works.
Boost addict
The Fleet:
Current project:
Upcoming projects:
'92 Bonneville SSE
'87 LeSabre T-type
'67 LeSabre
RIP:
'93 SE - L67
The Fleet:
Current project:
Upcoming projects:
'92 Bonneville SSE
'87 LeSabre T-type
'67 LeSabre
RIP:
'93 SE - L67
- 2000Silverbullet
- Retired Gearhead
Those high strength bolts require a much higher pre-load torque value. What did you torque them to.
If they were under torqued, they would fatigue crack.
http://www.hughesengines.com/Upload/pro ... ations.pdf
- MattStrike
'04 Dirtymax
'97 Camaro
I had them the same as the comp bolts - 23ft-lbs
Boost addict
The Fleet:
Current project:
Upcoming projects:
'92 Bonneville SSE
'87 LeSabre T-type
'67 LeSabre
RIP:
'93 SE - L67
The Fleet:
Current project:
Upcoming projects:
'92 Bonneville SSE
'87 LeSabre T-type
'67 LeSabre
RIP:
'93 SE - L67
