2000 SE, runs for 2 seconds then dies
bellis24
Year and Trim: 2000 pontiac bonneville se
Post by bellis24 »
My car runs for 2 seconds then dies i put in a know pump in and still dose this runs for 2 seconds then dies i reset the ECM by unpluging the battery for 3 hrs. and tap the - cabole and let it sit for 5 min then it will start right up
J Wikoff
Year and Trim: 1992 SSE
Re: 2000 SE, runs for 2 seconds then dies
Post by J Wikoff »
Sounds a lot like a bad MAF. Any codes?
bellis24
Post by bellis24 »
no OBD2 the MAF is bran new gust put it in 8 moth ago
bellis24
Post by bellis24 »
my dad went out to start his car it ran good then when he went to leve the car dies but when he stared it back up he hold the gas on it and ran so we pall out the old pump and put the olds intreg pump in it it stared right up and ran good for 2 moth then one day it runs for 2 seconds then dies so we poled it off the hyway and let it sit for 3 week. Pald out the olds intreg pump and got a $300.00 new pump got it in the car went to start it it runs for 2 seconds then dies that's when i reset the ECM by unpluging the battery for 3 hrs. and tap the - cabole and let it sit for 5 min then it will start right up then yesterday my dad tock it out for work it ran good drove it all day and it was 27 F out side when he was coming home from work it was 15 F and the car dies on the hyway so we had to tow it home agen right now i'm resetting the ECM and at 2:40 to day i will see if it will start back up
bellis24
Post by bellis24 »
http://www.youtube.com/watch?v=QjpcpUZh ... e=youtu.be (edit by moderator: LANGUAGE WARNING)
Sorry for the LANGUAGE but i was having a bad day and this was the end
#1. You should go wash your mouth out with soap, it was embarrassing to watch that video with my family in the room.
#2. Are you 100% sure the fuel pump is running during the no start conditions? You might want to try jumpering the fuel pump relay to see if that fixes it.
#3. What is your fuel pressure at the rail?
bellis24
Post by bellis24 »
sarey for the LANGUAGE i was unset and was getting mad at it
45psi at rail
i know the pump is working couse i can hear it inside of the car and i had a tester i mad for it litting up by me
bellis24
Post by bellis24 »
the car ran good all day and when my dad when to work and came home it dies the car had only 33 mis on it with the new pump and it dies that is what i don't get i fix a ford that was worth then this and it still running
bellis24
Post by bellis24 »
is most likely thiang to happening, is most likely a chip in the key and the chip is starting to wearing out can that be going on
crash93ssei
Post by crash93ssei »
I am having a very hard time understanding anything you are saying here, please use correct spelling and punctuation so it is able to be read and understood. All I can really understand so far is that the car runs but stalls quickly and I think the pump has been replaced, everything else I have no idea.
Franksdad
Year and Trim: 2001 SLE
Post by Franksdad »
crash93ssei wrote:I am having a very hard time understanding anything you are saying here, please use correct spelling and punctuation so it is able to be read and understood. All I can really understand so far is that the car runs but stalls quickly and I think the pump has been replaced, everything else I have no idea.
Also something about a key chip?
2001 SLE tints | Series III L26 | 180 T-stat |
2002 Monte carlo SS Dale Earnhardt edition (waiting on salvage title)
