Steering wheel
- samples08
- Posts like an L36
- Year and Trim: 2002 SSEi
88,000k - Location: Piedmont South Carolina
Steering wheel
Hey guys I have a question. I noticed that my steering wheel does not lock in place when the car is off, I know I read something that is a common break on our cars that needs to be replaced but I do not remember when or where I read it so I was wondering if you guys could offer some help.
Thanks in Advanced!
Thanks in Advanced!
Member #3848
- nos4blood70
Re: Steering wheel
It's common to get clunks while turning. I've never heard of issues with the steering lock.
If I remove the key and attempt to turn the wheel more than an inch or two, it locks right up.
- quicksilver
- Year and Trim: 2000 SSEi: Black w/ 145,XXX miles
Re: Steering wheel
My jeep takes a few inches to get it to lock, and its one of the nicest shape jeeps with the tightest steering ive ever seen. Try wiggling it back and forth as much as possible, seriously, then it should lock.
1995 Jeep Cherokee Country- 200,XXX miles and running strong. 4.0L paired with a 5 speed manual. 4.5" long arm lift with 32" tires and regeared to make up for power. Best of all, shes a fire engine red!
2000 Bonneville SSEi- 145,XXX miles, bonestock for the time (don't hold your breath, it might be a long while)
Typos courtesy of LG Optimus G- yes, I do most of my trolling with my phone. Don't judge me.
- samples08
- Posts like an L36
Re: Steering wheel
no it doesn't lock at all I am able to move the wheels a good bit (with alotta force) but my steering wheel never locks up at all and that is what also maybe causing my airbag light to be on.
Member #3848
- samples08
- Posts like an L36
Re: Steering wheel
Andrew do you have this part and if so how much?
Member #3848
DaMaroon
- SSEi Member
- Year and Trim: 2003 SE
Re: Steering wheel
Just assumed it wasn't designed to do that any more. No mention in owners manual. Maybe I haven't turned it far enough yet.
- crash93ssei
- Retired Moderator
- Year and Trim: 2002 SE
Re: Steering wheel
I don't recall either of mine locking, never cared enough to look into it.
- samples08
- Posts like an L36
Re: Steering wheel
The reason why I'm asking because I read somewhere that with the air bag light on the reason maybe a sensor in the steering wheel but I'm just tossing around this idea I really don't want to get charged 90 dollars to have the light checked!
Member #3848
- 1tinindian
- Posts like an LG3
- Year and Trim: 2004 SLE Premier Edition
2005 GXP - Location: Rockford, Iowa
Re: Steering wheel
When the airbag light is on, it could be any one of several electrical connections in the SIR system.samples08 wrote:The reason why I'm asking because I read somewhere that with the air bag light on the reason maybe a sensor in the steering wheel but I'm just tossing around this idea I really don't want to get charged 90 dollars to have the light checked!
The only true way to start to diag. the light, is to have the code read, and go from there.
You just can't assume something, or you'll just be chasing your tail.
I have found, that in a lot of cases, fretting corrosion has been the root cause to many air bag lights.
Leon
