5 years of other F40 swaps helps a bit too. Noah's GP swap, timka86's Grand Am swap, SteveX's Lesabre swap, and a hand full of Fiero swaps. While these helped, I was more or less on my own for all the mounts, clutch pedal setup, axles, and clutch line among other things.
First thing I did was mount the shifter and get the cables in the bay. The reverse lock out got chopped off and the rear HVAC duct was trimmed.
Next was figuring out how and were I would mount the G6 pedal. There's a large wiring pass through that suspends the wires in epoxy and a plastic cover. I was able to break all the wires free, hole saw a new location at the top corner of the original pass through, and get them up and out of the way for the MC. The pedal it's self was modified for more rebound throw to get everything lined up with the appropriate travel. I went through a few sheet metal revisions but ended up with a water jet cut part that the MC clocks and locks into, and it bolts up to the firewall.
Location ironed out:
2nd version of the pedal plate:
Final prototype:
http://www.youtube.com/watch?v=rSfeo79j2X4
Before and after with final:
Trans out:
I found out that I needed to cut the unibody quite a bit more so since I raised my drivetrain 1.5". (keeps my axles closer to neutral)
More on that later.
I also found out that I needed to modify my jet-hotted long tube headers.. luckily it was only the front:
All mounts were developed in CAD, test fitted by printing 1:1, water jetted, and welded where needed.
Rear mount location:
Front:
Rachel (Zuper8) was cool enough to make a bearing carrier for the intermediate shaft for me:
Zeroing in the bearing run out:
Final:
Tied into the rear dog bone:
And tied into the oil pan:
Complete mounts powder coated:
I went with The Driveshaft Shop for axles:
These are actually Cobalt SS inners, G6 outers, and custom length 300m centers.
The stock G6 driver's side axle fit with a Malibu front hub (like Noah's swap) but it was completely compressed so the driver's side needed to be shortened. The passenger side was a few inches too short. Colbalt SS inners were used to keep cost down since they make custom Cobalt axles a lot.
I beat around a bunch of ideas with the unibody work and decided I wouldn't be happy unless I did something I could smooth out like the rest of the bay.
Water jetted rails mocked up:
And working them in and boxing it up:
I finished boxing in the unibody work with 1/4" steel and added another rail in the wheel well area. The bottom of the vertical sheet metal that I left was curved inward and closest to the trans when mocking things up. I opted to cut that out and add that wheel well rail right above it. This gave plenty of clearance when installing the trans. I underbodied in the void where the trans sits and I primed and rattle canned the top. I'll revisit the top with some more smoothing and real paint later.
Clearancing the oil Jegs universal oil adapter and stock filter housing for the axle.
For the custom length clutch line, I called up Rogue Engineering in NJ. They sell a DOT approved SS braided line for BMWs that have the same quick connect fitting on one end. The G6 has this fitting on both sides.. I was thinking I may have to run 2 of their lines with a double male adapter connecting the 2. I asked them if they can make a custom length line and they said 'We can do anything you want'. I LOVE hearing that.. 2 days later I had a custom line in my hand for $85 plus shipping.
The only thing I was a little weary about was the size of the O-rings vs. larger stock G6, so I just swapped those over.
Spec clutch kit for a S2 3800 and F40:
The Hydraulic Throw Out Bearing spacer in the kit came on another HTOB that isn't the same as the G6. So, I just swapped the spacer on the one that came on my trans. The point of the spacer is to keep the HTOB from over extending when pressing into the pressure plate. The stock dual mass G6 setup has a higher stack height.
G6 on left
Clutch installed:
Bracket for the relocated oil housing and re worked -10AN oil cooler routing:
Bracket holds oil housing on the left.
G6 brake pedal:
More or less together:
Temporary shift boot:
The electrical side of things was made easier by Ryan at Sinister Performance and Micky Moose on Fiero.nl:
http://www.gmtuners.com/fiero/transbypass.htm
http://www.fiero.nl/forum/Archives/Arch ... 16755.html
And when I figured out that the Malibu hubs are 5-6mm shallower than 00+ H body:
^^ that kinda sucked and required a 5mm spacer behind the brake rotor to space it correctly in the caliper bracket.
I drove it around the block last night and back and fourth down my street.. *dang* that felt good.
My front alignment is way off and my tune needs some work but it runs and drives good.
Here's where it all went down..
