Rust Prevention below Gas Tank Door: How to Pictorial (long)
bobgto65
2004 Bonneville GXP
Post by bobgto65 »
How to prevent Rust-out around the gas tank door.
About 2 years ago there were a couple threads that explained many 2000-05 Bonnveille have rust-through around the gas filler door. This is also visible from inside the trunk if you remove the left trim. I owned a 2002 Bonneville SSEi and I started getting bubbles in the paint about 2 years ago. Now that I own a 2004 Bonneville GXP with only 33,400 miles, that was garage kept, with no sign of rust, I wanted to see what can be done to prevent the rust through.
The first three pictures are courtesy of Andrew from Bonnevilles Unlimited. They were posted previously. The picture below shows a view from inside the wheel well with the top half of the wheel well cut off.
Now with the wheel well removed we are looking at the quarter panel from the inside. This is also visible from inside the trunk if you remove the left trim. I will explain how the rust occurs in a little while
Here is the inside of the gas door on my ’04 Bonneville that was garage kept since new. If you put your finger behind the tab for the lower screw for the hinge, you can feel a small recess. There is a gap between the quarter panel and sheet metal for the gas filler surround near the tip of the arrow.
Once water get in here, if fills up a small pocket just underneath the bottom flat surface of the filler opening, along the quarter panel. See the blue areas in the pictures below. The water is trapped in this space and has nowhere to drain, as the space is sealed with hard black foam. Eventually the surface protection on the inside surface of the quarter panel sheet metal breaks down and rust begins. Over time, enough rust will form to let the water drain out around the foam seal and it leaks further down the quarter panel into the inside of the fender well. By the time the rust is visible below the filler neck sheet metal insert, there is already extensive rusting of the quarter panel sheet metal inside the pocket. Of course GM planned this so that the rust does not appear until one month after the 6 year 100,000 mile rust through warranty expires.
Here is a picture taken from the inside of the trunk on my 2002 Bonneville
And on the outside, you can see the extensive damage. It is too late to do anything except cut out the rusted area and have new metal welded in.
The outside of my 2004 Bonneville looks perfect and the view inside the trunk below shows no rust stains. But when I stuck a Q-tip inside the pocket it was wet and there was a slight rusty color so the rust has already started. The first time you drive your car in the rain or through a car wash, the pocket will fill up with water
Now that we know what causes the rust, the main steps to prevent progression are
1.) To dry out the water pocket,
2.) Coat the inside of the packet with a rust sealer/preventer
3.) Seal the inside of the gas door to prevent more water from getting into the pocket.
To dry the pocket out, I used my air compressor and an inflation needle. I cut a small piece of insulator off of a #14 wire and stuck it on the end of the needle. Then I taped the trigger of my air blower open, and using low pressure, inserted the tubing into the small notch at the back of the filler door and down into the pocket. I also inserted the inflation pin into the front gap just below the hinge screw tab. I tested the pocket with Q-tips until it was completely dry. This took about 2 days of blowing compressed air into the pocket to allow all the water to evaporate and get the pocket completely dry.
I chose Rust Bullet to prevent further rust. Some reviews state that it works better than POR-15 To get the Rust Bullet into the pocket, I used a 30cc syringe with an 18 gauge needle.
You only need about 10cc (2 teaspoons) of paint to fill up the pocket. The paint it pretty think so it takes a minute to two to fill up the syringe.
Just place the needle inside the back notch and empty the syringe . The paint will flow into the pocket. If you put too much paint in, then it will bubble up through the gap near the fuel door door hinge. It’s probable a good idea to mask the area to keep paint off the body.
You can fill the pocket with paint, but it will never dry or set, I let the paint soak in for 10 minutes then use the syringe to suck out the excess paint, leaving a coating of paint on the entire inside of the pocket. If you get any Rust Bullet on the finish, wipe it off immediately with a rag and some paint thinner.
Now it’s back to the compressed air. You have to let the paint dry which could take forever in a closed pocket. I blew compressed air in to the pocket, and testing with a Q-tip until no paint showed on the Q-tip, it took about 8 hours to dry. The next day. I applies a second coat of Rust Bullet and sucked out the excess, and blew it dry again. Now we have a dry pocket with 2 coats of paint, so any rust that is present will not be exposed to air or moisture and it will not rust any further. You can wipe any excess paint off the finish with a rag and some paint thinner if you do it right away.
Finally, it is time to seal off the areas so that no more water can get in. I used a clear GE silicone sealant. This stuff gets messy so a pair of latex gloves and plenty of rags are a must.
Before applying the sealant, clean the areas to be sealed and make sure they are dry. I am sealing the area inside the gas door along the bottom behind the hinge, the small gaps at the back edge of the gas door opening around the filler neck, both inside the wheel housing and inside the fuel door, and the small drain hole inside the fuel door just below the filler neck. I also put a small seam along the bottom welds.
The area behind the hinge requires the most sealant.
And here is what it looks like after applying the sealant. It looks messy but after I applied the sealant, I smoothed it out with my gloved finger and wiped off the excess with rags. Then I let it set for an hour and applied a second coat. Now the pocket is completely sealed so no water can get in and there should never be any rust through. But I will have to wait several years to find out if it really works!
bobgto65
imidazol97
Re: Rust Prevention below Gas Tank Door: How to Pictorial (l
Post by imidazol97 »
This should go into Techinfo!
bobgto65
2004 Bonneville GXP
Post by bobgto65 »
Perhaps the moderator can move it.
bobgto65
CMNTMXR57
Post by CMNTMXR57 »
YES!
Daily Drivers:
2011 Camaro SS
crash93ssei
Post by crash93ssei »
I would take a little silicone mess inside my gas door over rust all day long! Wayyy too late for our SSEi, and even the Mutt has two very tiny bubbles so it may even be too late for that, though this would at least make it last longer.
carl
Year and Trim: 2002 Buick LeSabre
Post by carl »
On already rusting vehicles... what about just cookie-cutting out the whole gas door area from the outside, replace or repair the rusted areas on both the piece that was cut-out and the fender area that it was cut from. And then weld the gas door area back in from the outside.
Or better yet repair and seal the whole dang thing off and run the gas filler neck up into the trunk:).
flatlander745
Post by flatlander745 »
142,000 on my 00 SSEi and no signs of decay!! :beerchug:
Wish I could have seen this earlier. Only spot on my car where I have rust. Ironic.
bobgto65
2004 Bonneville GXP
Post by bobgto65 »
If it already rusted through you can get a patch panel from harofreak00. The body shop I used to fix my 2002 Bonneville thought it would have been easier if the patch panel ran all the way up to the edge of the door opening.
bobgto65
carl
Post by carl »
Well, its a lesabre but the gas door isn't important, I can patch in a panel/pontiac door. Please post the best way to contact harofreak00 for this.
bobgto65
2004 Bonneville GXP
Post by bobgto65 »
The panel is going to be different because the sheet metal is not the same. It will not work.
bobgto65
carl
Post by carl »
All I am really interested in is cutting out the existing pocket (area behind the door and just enough around where the foam seal is) and replace that whole pocket with whatever door it needs. I just need enough panel metal to weld it in. Its another h-body in the same series years, so I am pretty sure the neck will mount right up and the depth should be close enough to modify if needed..
Archon
Post by Archon »
imidazol97 wrote:This should go into Techinfo!
Added to Techinfo/Exterior
cjramsey
Year and Trim: 2005 Bonneville SE
Post by cjramsey »
thanks, good clear information. FYI - I checked my 05 SE (162k miles) which has been outside most of its life and no signs of water in the cavity or any rust. I will go ahead and put in some rust inhibitor and seal with silicone as you suggest however.
carl
Post by carl »
How about some type of silicone putty for the crevices? It maybe less messy on the outside and it can be pushed deep into the crevices. What you guys think? Something like the thicker material they use for tire repairs now.
Ziebart used to have a thick clear shell they would use for surface areas like inside the gas door, but it was more amber than clear and stayed soft but not tacky. Almost like a clear undercoating but harder.
1oldman
Post by 1oldman »
Just an observation from using silicone in tub/tile/shower areas re: Silicone Clean-up. I've had great success using alcohol. Takes silicone off fingers and other unwanted locations on, man, beast, tile and otherwise. - BC
AndrewK1854
Year and Trim: 2003 SSEi 170k
2003 SSEi 115k
Post by AndrewK1854 »
The pictures were viewable just a few weeks ago. I was just going to follow this guide for my 03 but now the pictures are gone. Any way this could be fixed
96 SSEi
Post by 96 SSEi »
please load the pics also
2000 SSEi
past rides:
1996 SSEi
1992 GTP
1987 Grand Am
AndrewK1854
2003 SSEi 115k
Any way to load the pics?
