Power mirror issue
Power mirror issue
I have an 05 GXP, and I use the curb view for the passengesr mirror. When I put the car in drive the mirror only comes back half way or not at all. Anybody know What should I be looking for?
PaulyGXP
- SSEi Member
- Year and Trim: 2004 Pontiac Bonneville GXP
Re: Power mirror issue
The mirror returns to its saved preference based on the memory function. Set your mirrors, seats, radio station and so on to where you want them with the car running in park. Then hold the number 1 or number 2 button on the door panel until it beeps. It should return to your desired position after shifting from reverse to anything else. It sounds to me like it is just not saved into your settings.
~Pauly~
It has been working for a couple of years. Guess I can go back and recheck the settings.
After some research that feature is on or off. There doesn't appear to be any settings for it.
I reset the settings just for giggles. The mirror does the same thing. comes up a little and struggles and stops. Manually it goes up and down fine. Guess I can just turn it off or raise it myself every time. Guess if that is my only complaint, I should be glad.
This has been discussed before. I believe it's a problem with the pin behind the mirror that detects the position of the glass.
- sethjamesrimrodt
- Posts like an L36
This was my issue.harofreak00 wrote:This has been discussed before. I believe it's a problem with the pin behind the mirror that detects the position of the glass.
Seth
So live with it or replace the mirror? Thanks Harofreak.
- Bonneville'n
- Year and Trim: 2000 SSEi
I replaced a my cracked mirror and have been having this issue ever since...is there a reset or procedure to do after replacing the mirror??ZimGXP wrote:So live with it or replace the mirror? Thanks Harofreak.
240k, Cleared Corners, Silverstars, Yellow 893 fogs, LED Marker,
Reverse & interior bulbs, L32, Triple Edge
transmission, Intense FWI, N*, GXP Brake & Swaybar Swap, Pacesetters
You probably just didn't get all 4 pins connected.
