4T65 TransGo shift kit installation
- Larz01
- SSEi Member
- Year and Trim: 2K1 GTP
Re: 4T65 TransGo shift kit installation
just get (2) 1/2" long steel spacers, 1/4" id, 3/8" od (place on top part of piston)
(2) 3/4" long steel spacer,...."...." (place on bottom part of piston)
= $3 from Ace hardware, or wherever you chose.
Buy a 2-3 spring and replace it in the place of the 1-2 spring.
= $9 from local GM dealer
=$12 shift kit same thing.
Just Your Average open loop tuned Ethanol Driven DD's
2k1 GTP: 13.307 @ 104: Headers, 1.9's, Tune
2k12 Impala: Stock
2k12 Impala: Stock
LeSabre in Buffalo
- Year and Trim: 2012 Eco
Update on the shift kit: Still working flawlessly. It's still shifting very fast and very smoothly. Still recommended for a one-stop shift kit. Yeah, it's pricey. It's also worth it for masking or helping to prevent PCS issues.
- 2000Silverbullet
- Retired Gearhead
Bang screech baby......BANG SCREECH !!!
LeSabre in Buffalo
LOL!!!
Bang-screech this kit isn't! Just smooth and fast, like a shot of premium liquor.
LeSabre in Buffalo
Update: With 16k miles on the kit (installed at 78k miles, just hit 94k miles yesterday), there are zero issues to report. My ATF is still cherry red, and the transmission is shifting just fine. No change in shifts from installation to now. Still fast and smooth.
LeSabre in Buffalo
I guess final update: at 102k miles the PCS finally bit the dust, so it was replaced. A local shop did it for $450 including an alignment. The car puts power to the ground very nicely now.
- comatoast
Anyone notice a shifting/ acceleration difference by going to the hockey puck (solid ) front mount?
Current mods - FWI, Intense 1.0 PCM, 3.4"- 3.5", Intense MPS, AL 104s, 180 Stat , Intense/TG shiftkit, Aeroforce Interceptor scan gauge
Upcoming mods- 1.9 rockers, 105#springs, Headers, 103s, 3.3, tune..
part number?Larz01 wrote:Buy a 2-3 spring and replace it in the place of the 1-2 spring.
*edit*, nevermind... found it here: http://www.w-body.com/showthread.php/32 ... tall-Guide
GM PART # 24203977
CATEGORY: All
PACK QTY: 1
CORE CHARGE: $0.00
List Price: $8.28
Price: $4.81
You Save: $3.47 (42%)
DESCRIPTION: SPRING
Goodfellow
- Year and Trim: 1997 SSEI, premium spark wires and iridium plugs.
so is the shift kit sold at zzperformance any good? it looks like the spacers are plastic
and is it a good idea to put a shift kit on a car with 200,000 miles on it?
Goodfellow
What is PCS?LeSabre in Buffalo wrote:I guess final update: at 102k miles the PCS finally bit the dust, so it was replaced. A local shop did it for $450 including an alignment. The car puts power to the ground very nicely now.
xcbullet
- SSEi Member
- Year and Trim: 2000 SE, transg kit & B&M trans cooler
Just did the transgo kit & b&m cooler (LPD). I just used the springs per the kit but did use a half inch spacer in the second gear side. The cooler mounted nicely on the tubes under the hood latch, it runs vertical. Could not get the fitting out of radiator so cut the lines & sanded them fresh then installed two clamps opposite each other on each end took out about two inch section about two inchs down from the top. I changed fluid 20ooo miles ago couldn't be leave how dark it had gottin already. Will change again in 20 then see if the change helped at all. History of car came from Texas had 90ooo whin I got. Last year was shifting strange one day on exspessway then I but trans tune in it been ok after that. Have towed with it when I moved used snowmobile trailer for some of the stuff. Used 3rd when towing wish I would have had trans cooler then. Bonus when working on car found bad clamp on radiator overfill hose. Hose was doubled over on barb, looked like from factory that way. Was losing coolant like half inch ever 6ooo miles about. Thought was going to have to do intake looks like can wait on that for a while but sure it's time is coming.
Shifts fine like it did when driving normal where u can see a changes is when getting on it nice & firm.
