Last tank: 20.2
I give up!
Come winter time, little ricer boy better watch his @$$, because by golly if this car is going to tear through gas that fast, I am going to give it a reason to tear through gas that fast!
I didn't, I was figuring the computer would figure it out, but I can see the wisdom in your suggestion. Thank you.BonneMe wrote:Did you reset the computer by taking the battery wires off for 30+ minute to reset fuel trims? And give it a tank or two to come back... You're probably flooring it too much.
The '91 Olds, when it sees 30-50mph all city stop & go, gets 17-20 mpg as well, though if you go 100% highway with few if any stops, it'll do 29 mpg, even at 70mph. My '98 Z34 L36 got nearly identical mileage as well in identical conditions. Don't know what your makeup of driving conditions are at, but what will it get on a 100% highway trip, with average acceleration?gmman wrote:just for your comparison, i drive a 95 PA NA Jacksonville FL. mostly suburban meaning 35-45 mph speed limits. seldom ever shifts into OD. i think it has the 2.86 gear ratio. gas mileage always between 18-20 mpg.
yourgrandma wrote:High
Yeah, I wouldn't get my hopes up for anything better than 27-30 mpg on a highway trip. I've known a couple people that could squeeze 32 or so out of one, but in all cases they were Series II cars with the tall gear ratios. Anything 32 mpg or better is usually done babying the car on a 100% all highway drive with no stops. The 3800's are good but not that good under normal circumstances. Any mid 30's to 40 is a rare occurance that may only happen a couple times in the ownership of the car.RJolly87 wrote: I just remember people mentioning 30's on the road, with BonneMe menioning a 40mpg run accross MI.
Perhaps expecting too much?
