Tutorial - Wrapping 2000+ dash vents in 3M 1080 vinyl
crash93ssei
Post by crash93ssei »
This write up is specifically for wrapping the 2000+ dash vents using 3M 1080 carbon fiber vinyl, but other interior parts on all years as well as different vinyl materials will also be a very similar process.
I ordered a 1'x5' roll of the vinyl from amazon.com for about $21 shipped and I still have a TON of it left, more then enough to do several sets of vents.
Remove the trim bezel from your vent housing, it just pops off. Clean it thoroughly with rubbing alcohol to remove any oils and dirt that may be on it to ensure a good hold for the vinyl.
Lay the bezel on the wrap and cut out a section slightly larger then the overall size of the part you are working on.
Peel the backing off the vinyl and lay the vinyl sticky side up on a flat surface, then lay the part down as centered as possible on the vinyl
Pick the part with the vinyl attached, careful to not touch the sticky area as much as possible. If it is relatively flat you can just slowly work around the outside edges to get the basic area laid out, if it is not very flat use a blow dryer to add a little heat and make it smooth over the outer surface.
I set the blow dryer on high heat, low fan speed on it's side on the edge of the counter to leave both of my hands free to work. Start with the outside edge, pull and stretch the vinyl over the edges, curves are the hardest part as the vinyl will want to wrinkle when going around them, just keep heat on it and pull it tight enough to remove the wrinkles then press and hold the vinyl to the surface until it cools and holds, usually a couple seconds.
Continue your way around the outside and you end up with this.
At this point you can cut little slits inside the area to be drawn into the vent area
Heat it up again and begin to work it down.
When you get to the bottom of the vent area, cut off all but about 1/8" and cut little slits in that all the way to the edge of the vent so you can heat it and bend them over the edge on the back side.
Start on the other side repeating the process, I found that more slits makes it easier to stretch.
Cut a few slits in the vent adjust section, one right down the middle and two on either side by the curved edge to make it fold into the inside easy.
Heat and wrap that around to the inside.
You now have a finished vent bezel.
PLAGUE PHANTOM
Year and Trim: 1968 Chevrolet Bel Air
Re: Tutorial - Wrapping 2000+ dash vents in 3M 1080 vinyl
Post by PLAGUE PHANTOM »
Good tutorial. I will be doing this to the dash trim bezel for my 97. Looks good
1997 Bonneville SLE...(SilverStreak)...Totaled...1/25/13...Gone but not forgotten.
1968 Chevrolet Bel Air....the project
yourgrandma
Year and Trim: '02 SSEi
Post by yourgrandma »
Got a lil wrinkle there.
It looks quite good. I may not have a market for real carbon pieces now. lol
crash93ssei
Yea, still not 100% perfect, this was only the second one I did :lol: any wrinkles seen here though are completely hidden by the dash, so I wasn't too worried.
DCJREDLINE
Year and Trim: None
Post by DCJREDLINE »
Very nice work man. Im not sure I have the patients for that. At least I dont for myself, maybe if someone was paying me to do it.
2004 Saturn Ion 3 Quad Coupe
SSEiMan01
Post by SSEiMan01 »
Good writeup Ryan!
Some may want to paint the grilles and adjustment cones black like a GXP vent, could use Krylon Fusion for that. Easy to use and holds up well. My OCD may get bothered by the gray. Other than that I like em a lot!
James May wrote:Hello.
ChilinMichael
Year and Trim: 2004 Volvo S60
Post by ChilinMichael »
Nicely done!
I'm actually starting to like this better than GXP.
sethjamesrimrodt
Year and Trim: 2004 GXP
Post by sethjamesrimrodt »
nos4blood70 wrote:I'm actually starting to like this better than GXP.
I like them a lot better then GXP vents, they look really nice.
Seth
theax40
Year and Trim: '03 SSEi
Post by theax40 »
Yea this is awesome. Way easier and cheaper than hunting down real GXP vents and these look better. And a nice write-up.
Chris
2003 SSEi|Galaxy Silver Metallic
crash93ssei
I am glad to see that many of you like this look! I honestly thought I would get a lot of people saying the exact opposite, that they hate this and the GXP looks much better and that this looks cheesy etc...
The vents aren't too terribly hard to do, but wow.... I just got done after about an hour or so working on one door handle bezel! Those are touchy, but wow does it look amazing!
sethjamesrimrodt
crash93ssei wrote:I am glad to see that many of you like this look! I honestly thought I would get a lot of people saying the exact opposite, that they hate this and the GXP looks much better and that this looks cheesy etc...
Pictures of those somewhere??!! Please!
Seth
crash93ssei
I know you already seen them and replied, but just in case others are curious as well - viewtopic.php?f=27&t=32634
theax40
Post by theax40 »
Yea they really look good man. I saw a thread a while back where someone had their GXP vents re-wrapped in carbon fiber and it showed how brown the factory carbon fiber was and how it doesn't really match a gray interior. Might have been Andrew, I don't remember.
Chris
SSEiMan01
Post by SSEiMan01 »
Chris, that was ddadler... ;)
theax40
Post by theax40 »
That's right, thanks Will. That's one of those threads you find after cruising all the old posts cause you can't get enough Bonneville.
Chris
One more thing to add, is if you know you've used a lot of Armor-All or something on these, it would not be a bad idea to wash them using Tri-Sodium Phosphate, which you can get at a hardware store. It's a strong cleaner and will pull all the oils, grease, dirt, etc out of the grains of the plastic which can reduce adhesion of the vinyl over time. Even a quick wash in some soapy water would be better than nothing.
Definitely still wipe them down with alcohol before applying, but this is a good intermediate step to insure long-term full adhesion. Also works well if you're painting plastic or vinyl parts.
Just like anything else, the better you prep, the better the end result will be.
WhiteArrow3800
Post by WhiteArrow3800 »
Oh yours has an adhesive backing...what I used was actually more of a fabric and I had to use headliner adhesive spray.
Not sure which would be easier...I'm sure there's some pros/cons to both.
I need to finish/redo what I've done so far.
But in any case, nice work Ryan, as always!
Last edited by WhiteArrow3800 on Tue May 08, 2012 4:10 pm, edited 1 time in total.
SSEiMan01
Post by SSEiMan01 »
00Beast wrote:One more thing to add, is if you know you've used a lot of Armor-All or something on these, it would not be a bad idea to wash them using Tri-Sodium Phosphate.
That's one way, but I used paint thinner on everything I painted, it worked great. Paint thinner, not mineral spirits though, a lot of people mistake the two. (Years of retail hardware experience speaking.)
jreigner
Year and Trim: 2000 Bonneville SSEI
Post by jreigner »
Clean it with alcohol and put primer 94 on the edges. The natural tendency for this vinyl is to straighten in the heat. All those compound corners are going to lift in the heat.
