motor mount
deano55
Year and Trim: 2003 Bonneville SSEI
motor mount
Post by deano55 »
I noticed the other day when I was trying to find where the exhaust leak was coming from, that the exhaust system flexed more than what I thought it should. A friend put the car in gear and while steping on the brake and throttle at the same time I could definantly see the flexing. How much is normal? A inch of down movement at the collector? Or is my motor mount in need of replacement at 70K?
Re: motor mount
Do a solid front mount.
deano55
Re: motor mount
Post by deano55 »
How's the vibration with a solid mount?
Re: motor mount
With a bushing, barely noticeable. The only times you really feel it, in my car at least, is between 1400 and 1700 RPM.
Re: motor mount
I never feel it at all in my car.
deano55
Re: motor mount
Post by deano55 »
ok, where do i get one?
Re: motor mount
Your local hardware and sporting goods store.
Threaded rod, nuts and a few hockey pucks.
Re: motor mount
67goat
Year and Trim: '01 SSEi
Re: motor mount
Post by 67goat »
deano55 wrote:ok, where do i get one?
I used polyurethane body bushings, then added a rubber body bushing on top of that to help isolate some vibration. You get just a tiny bit of vibration over stock, but IMO, the decrease in engine movement outweighs the very minor vibration you might feel. Actually helps suspension control and seems to decrease torque steer.
_________________________________________________________________
2001 SSEi - NEW MODS in L32 - FWI, colder plugs, 180 t-stat, 3.5 pulley, 1.95 rockers, TOG headers and just about every Intense Trans upgrades they recommended.
OLD MODS in L67 - include FWI, colder plugs (Autolites), 180 t-stat, 3.4 pulley and 1.95 rockers.
(Previously owned '95 SSEi, RIP)
deano55
Re: motor mount
Post by deano55 »
Do you have pictures? What about mc master carr? They have 3-4" polyurethane round stock in many hardnesses, do i want it as hard as a hockey puck or a little softer?
bobtaz13
Year and Trim: 2001 SSEi
1991 SE
Re: motor mount
Post by bobtaz13 »
Here are some photo's of mine. I made it from some polyurethane body lift blocks. With the part on the top there is very little vibration.
2001 SSEi | Galaxy Silver | GenV supercharger P&P | Intense 3.2 MPS | Intense FWI 4"| Custom PCM | TOG Ceramic headers | Magnaflow 3" cat | 180° stat | Aeroforce scan gauge | PRJ plug wires | PRJ fuel rails | Silicone vacuum lines| AP103 plugs | 3.2 MPS | 42.5# injectors | Intense 1x cam kit | YT 1.8 Rockers | 105# springs | Meziere HD pump | N* Tb | 185mm MAF | 2" Phenolic Intercooler | Oil pressure kit | L32 short block | 5% overdrive SFI Balancer | L67 heads custom ported | EBC USR Rotors | EBC Red stuff pads | Custom HID Fog lights, with HI-beam over ride | Polyurethane motor mount | Energy Suspension end links | GXP Shocks/Struts | Custom Drop springs Front, Rear FE5 Springs | GXP Strut tower Brace | GP GXP 18x8 Rims | Polished Exhaust tips | Triple Edge High Performance Street/Strip 4T65E-HD |
deano55
Re: motor mount
Post by deano55 »
bobtaz13 wrote:Here are some photo's of mine. I made it from some polyurethane body lift blocks. With the part on the top there is very little vibration.
Is that a piece of 3" pipe? Looks good
