Stuck Brake Lines!
Talk about the other 3800 powered GM cars, particularly for items not covered in other sections that may be unique to your year/model, and differ from a Bonneville.
Tricked-T
Year and Trim: 1988 & 89 Buick Lesabre T-types
Stuck Brake Lines!
Post by Tricked-T »
I ave some brake lines that are STUCK and I mean STUCK on the master cylinder. I do not want to replace all the lines. Any suggestions?
Re: Stuck Brake Lines!
PB blaster for a couple days.
:stupid:
That and fitting wrenches...
Tricked-T
Post by Tricked-T »
PB blaster, heat, vice grips all tried
01bonneSC
Year and Trim: 05 Chevy 'Hoe
89 SkiDoo
Post by 01bonneSC »
Did you let the PB soak for a few days while re applying it a couple times a day?
And Im guessing the fittings are all rounded now that you used the vise grips?
Tricked-T
Post by Tricked-T »
I did let it soak for a couple days. No the fittings are not rounded. We were very careful not to.
Archon
Post by Archon »
As 00Beast mentioned, use a flare wrench. It will give you a better grip with less worry about rounding off the flats. Even these from Harbor Freight would do.
http://www.harborfreight.com/5-piece-me ... 99993.html
Tricked-T
Post by Tricked-T »
Thats what I have been using, still no luck
Archon
Post by Archon »
It sounds as if you may need something with more leverage. At this point, about the only thing that comes to mind is using a small pipe wrench on the fittings. That will likely end up putting gouges on the flats.
I would just use another wrench on the flare wrench for some more leverage. That way you don't mess up the flats. Be prepared for stuff to break, though...
Tricked-T
Post by Tricked-T »
good idea.. and ya I really don't want to deal with a messed up brake line
