Rear 6x9s, Advice.
Gagger14
Year and Trim: 2010 Dodge Ram SLT Big Horn
1995 Chevy Camaro Z28
Rear 6x9s, Advice.
Post by Gagger14 »
I'm looking to replace my rear 6x9s with JL audio C2-690tx speakers and was wondering if any of you installed these before? Opinions on JL audio? I currently have the stock monsoon sound system and the factory speakers sound...well...disappointing especially in the bass department. I will also be changing the door speakers, but just haven't decided what I'm going to go with there yet... Let me know what you think, thanks!
In My Garage:
1995 Camaro Z28 - LT1 w/ 6-speed, Magnaflow Exhaust, Moroso Cold Air Inake, Powerstop drilled/slotted rotors and ceramic pads, Z06 Chrome Wheels, Founders Performance Strut Tower Brace (Work in Progress)
2010 Dodge Ram SLT Big Horn Edition Quad Cab - 5.7L Hemi, 390HP, 4x4, Daily Driver
Past Vehicles:
1989 Acura Legend - 'Tank'
1999 Dodge Dakota Ext. Cab - 'Bulldog'
2004 Bonneville GXP - 'Red Demon' - Already Missed
***Showed up expecting a battle, left with a laugh***
yourgrandma
Year and Trim: '02 SSEi
Re: Rear 6x9s, Advice.
Post by yourgrandma »
I always suggest saving the money you'd spend on rears and putting it towards better fronts. I'm not sure if you plan on using upgraded amplification or any subs either, as both of these will be facotrs in my advice.
Gagger14
Post by Gagger14 »
yourgrandma wrote:I always suggest saving the money you'd spend on rears and putting it towards better fronts. I'm not sure if you plan on using upgraded amplification or any subs either, as both of these will be facotrs in my advice.
Well now if I decide to keep the car, I would plan on changing out all the speakers, the head unit, and also getting an amp. Its just as of right now, my rears are in much worse shape than my front speakers as my front ones still sound pretty good minus a raddle coming from the door panel.
In My Garage:
Past Vehicles:
crash93ssei
Post by crash93ssei »
Are the rears blown? You mention in another topic that they make a horrible sound.
I have the monsoon system in my '03 and while it doesn't exactly sound like I have a set of 12s in the trunk with a big amp, I definitely wouldn't say the setup is lacking in the bass department especially for a stock system. Mine is fairly clear and loud, can pound out some decent bass as well.
Gagger14
Post by Gagger14 »
crash93ssei wrote:Are the rears blown? You mention in another topic that they make a horrible sound.
I don't believe they are blown... It's not so much that they make A horrible sound, they just produce horrible sound. Its almost as if I have no speakers in the rear, very quiet. I was just expecting a lot more out of a "premium" monsoon system.
I am not looking for a ton of bass, just something I can enjoy when I feel like bumping it a bit. I plan on replacing the factory 6x9s with a set of JL Audio C2-690tx speakers. Hopefully that'll do the trick...
In My Garage:
Past Vehicles:
crash93ssei
That is pretty odd. I know they are set up so that the rear 6x9s are only subwoofers and the rear door speakers are full range.
I almost wonder if there is something going on there causing them to be quiet.
I know Jerry replaced the stock rear 6x9s in his GXP and was very happy.
*Edit*
Nevermind, it was his front speakers he replaced.
Gagger14
Post by Gagger14 »
crash93ssei wrote:That is pretty odd. I know they are set up so that the rear 6x9s are only subwoofers and the rear door speakers are full range.
*Edit*
Yeah I found it pretty odd, so I just figured I would avoid the problem and update them instead figuring aftermarket speakers are usually better anyway.
Also, a little off topic, but do you know if our Bonnevilles accept double DIN HUs? Or would a ton of work have to go into it? Thanks for the help.
In My Garage:
Past Vehicles:
crash93ssei
Not sure myself on a double din, I haven't ever looked into replacing the stock head unit so never bothered to do much research on it. I believe it has been discussed here a few times before though.
Ryan from Ohio
Post by Ryan from Ohio »
JL Audio is one of the best audio companies out there. I have noted that lately they have more of a budget lineup- so beware that it may not be the absolute best but since its JL it should be good still. My first real subs were JL's- W1 12's (there now you guys can date my experience).
99% of the people just simply dont understand or cant comprehend the makeup of a good sounding car.
My advice is to either run 6x9 woofers:
http://www.parts-express.com/pe/showdet ... er=264-837
Or to find a nice two way 6x9:
http://www.infinitysystems.com/car/prod ... Region=USA
These are nice also:
http://americanbassusa.com/product.detail/product_id/17
repinS
Moderator
Moderator
Year and Trim: 09 G8 GT
Post by repinS »
crash93ssei wrote:I know Jerry replaced the stock rear 6x9s in his GXP and was very happy.
*Edit*
JBL 6x9's are in the mail :wink: : http://www.bestbuy.ca/en-CA/product/jbl ... 22104.aspx
Because I'm keeping the stock head unit with no plans of upgrading any time soon, I do have to get creative with connecting to match the Monsoon setup. It will take some snipping, splicing, and soldering to have the woofer portion connected to the Monsoon amp, and the tweeter connected to the head unit output. It'll instantly kill the warranty, but I've voided worse! I'll report back on how that goes. :)
Ryan from Ohio
Have any of you actually looked at the guts of a stock amp?
Weak sauce...
Now this is pure sex:
Last edited by Ryan from Ohio on Thu Jan 05, 2012 8:48 pm, edited 1 time in total.
