Left rear parking brake inop
tracerprix
- LE Member
- Year and Trim: 2005 SLE
I noticed that my left rear parking brake doesn't hold the wheel. It seems to move ok when you push the pedal. I did not compare it to the right side which works perfect. What do I need to look for to figure out why this doesn't hold the wheel. I took the caliper off and it seemed to be adjusted right. Thanks!
- Archon
Re: Left rear parking brake inop
Odds are that the cable on that side is binding and not moving as far as it should. You can try lubing it.
tracerprix
- LE Member
Thanks, I will try that, or replace that cable.
- Archon
Replacing would be the better option. I haven't had much long term success with lubing them.
tracerprix
- LE Member
I wouldn't think lubing the cable would last very long.
