supercharged 91 , pcm tuning list
tpulliam79
Year and Trim: 1991 SSE+I. 1994 ssei
Re: supercharged 91 , pcm tuning list
Post by tpulliam79 »
darn it, gonna get put off again, my moms car is having charging issues so I have been working on that , and we are going to look at 6 house possibilities :banana: . one of these days I will get to work on it :)
1991 SSE+I ( supercharged)
1994 ssei
WCBF '08
tpulliam79
what a week , hopefully next week I will have more time to dig in to the bonnie, I had to find a daily driver but now that that is accomplished I can turn m7y focus to the bonnie :twisted:
1994 ssei
WCBF '08
Wes
Year and Trim: 2002 Buick Park Ave
Post by Wes »
Ryan at Sinister most certainly can make the 92 prom run the 94-95 m62. Thats actually exactly what he did for my buick. only had to send it back once. when tuning from 200 miles away using data sent in e-mail, thats pretty darn good.
Do you have a scanner that will be able to collect live data from the sensors?
yourgrandma wrote:High
willwren
Post by willwren »
He may not need a scanner. He can use your BIN file for a starting point. Does Ryan save them?
tpulliam79
willwren wrote:He may not need a scanner. He can use your BIN file for a starting point. Does Ryan save them?
In his email to me he said he has all the stock files :)
1994 ssei
WCBF '08
willwren
Post by willwren »
I knew THAT....what I'm getting at is someone did this before you, and his first burn needed to be re-done. Using his second bin file might be possible. ;)
Wes
Post by Wes »
I believe he does save them.
tpulliam79
so getting ready to sell my dd my jeep. I am thinking about taking some of the money and getting the 91 up and going :banana: :banana: ...other option is to pick up another car for a dd and having to wait longer to get the bonnie going :dontknow: ... either way itll run at wcbf 12... Also spokane has a great raceway again so itll run there before then hopefully :beerchug:
1994 ssei
WCBF '08
tpulliam79
So i'm hoping to send the chip out today, i need to confirm if its a 92 or 94 tans . The engine is from a 92 for sure, the supercharger is a 94 so the trans may be either from what im finding out. Does it make a difference in the tune on which one it is? Or do i just have the 94/95 shift points burned in since the supercharger is a 94?
1994 ssei
WCBF '08
sandrock
Post by sandrock »
Tunewise, it won't matter, so long as the FDR and the shift points are there.
willwren
Post by willwren »
The tune needs to command the shifts at the higher 94/95 level in order to take advantage of the different powerband regardless of transmission. Tell Ryan you want 94/95 shift points.
tpulliam79
Alright got most of the info i need, i am going to flush the cooling system and change the thermostat since its been sitting so long, what temp thermo should i use? Also the exhaust is stock to the 91 (2") and sinister needs to know the size of exhaust, should i just leave it stock for now and for the tune or should i factor a change into the tune?...also the injector numbers are as follows 17102768...are these stock ? i think these are the last things i need to know so i can send my chip out... :bwoohoo: :bwoohoo:
1994 ssei
WCBF '08
sandrock
Post by sandrock »
Go with the 180* and have the fan temps set accordingly. The PCM won't care what exhaust size you are running.
willwren
Post by willwren »
Your 2" exhaust won't cut it with that motor. You'll be wanting 2.5" before you're done. Tune for that, or you'll have bad KR.
You got the wrong number off the injectors. Give us the other number. They should be 29lb.
tpulliam79
The o")6 other numbers I saw were 1293:::I will look gain in a bit. Also the trans pinout posted earlier in this topic doesn't match the colors I have on mine which leads me to believe the trans may be a 94 how can I verify this?
1994 ssei
WCBF '08
willwren
Post by willwren »
There might be problems here.....which PCM are you using?
The 92/93 use a thermal switch for overtemp cutoff. The 94/95 use a thermistor (in the valve body) which reports an actual temperature back to the PCM. If it's a 94/95 trans, you'll need a 94/95 PCM to run it.
You're going to have to take a closer look at those injectors. Your numbers aren't right. I might be able to give you some pointers later (I have a spare set at home).
tpulliam79
Pretty sure the pcm is a 92, how do I identify the transmissiontransmission?..also the only numbers on the injectors are
1293. 17102768 I know the heads were sent off for a 3 angle grind and am thinking he may have used bigger injectors. I will try to contact him to see if he remembers what they are from..
1994 ssei
WCBF '08
willwren
Post by willwren »
A 3-angle job would by no means require bigger injectors. If he got bigger ones, don't use them. You want stock 29lb injectors. We'll want jr's3800 to chime in on the trans. You need to look at the trans for a code on a tag or any other identifiers. Also give us the wire colors if the harness for the trans is there (and it's original).
tpulliam79
I don't know for sure that he used bigger injectors and im also not sure if its the original to trans wiring harness..ill see what I can find out about the injectors. And also get under the car and try to find any numbers on the trans...ill update with the colors of the harness that is for the trans this afternoon. I have my little ones till about noon or so.
here's a couple pics of the injectors: update , the injectors came from the same car the 94/95 supercharger was on but he can't confirm they were stock.
1994 ssei
WCBF '08
tpulliam79
The colring of the wires coming from the trans are as follows ( im not sure they are orig to trans yet or not):
Tan/blk
purple
light grn
drk blue
brown
yellow/blk
Red
1994 ssei
WCBF '08
