thinking of buying ths car ? is it fixable
LouderBonneville
Year and Trim: 1998 Pontiac Bonneville SE
Post by LouderBonneville »
well iam thinking of buying a car from copart and all i have is pics . just wondering if someone can look at the pics and tell me if its fixable ? does it look like it has frame damage ? it does not need to be perfect just fixable ? it is a 2000 SSEI with 140 k . inside is Clean , runs and drives .
repinS
Moderator
Moderator
Year and Trim: 09 G8 GT
Re: thinking of buying ths car ? is it fixable
Post by repinS »
I'd consider that one to not be worth your time. I would expect floorpan damage behind all of that, and the quarter panels look like they're a bit crinkled.
LouderBonneville
well if not i guess i will part it out . i have the winning bid right now of $200 bucks
Definately not worth fixing, its a parter outer for sure.
Don't plan on winning with your $200 bid... it will go for more than $1000 for sure.
LouderBonneville
i know for sure it wont go for 200 i put a max bid of 750 . since iam close and could maybe drive it home . or i have a freind with a truck . and i will go to uhaul and rent a car dolly .
2002Bonneville
Year and Trim: 2002 Pontiac Bonneville SLE
Post by 2002Bonneville »
Hopefully you can pick it up for fairly cheap - I bet the wheels alone could easily fetch near $1000 if you cleaned them up. If you do end up winning though, I'd take it to a mechanic anyways just to get confirmation as to whether or not there is chassis damage. That way at least you know for sure it would be a part-out car.
Too bad though, because the rest of it looks nice. Just not big on that shade of brown. I see so many Bonnevilles in that colour and it always confuses me since there are much nicer colours available!
Driving a car is like commanding a submarine - the deeper you go the better your chances!
GoldenBullet
Year and Trim: 2001 GMC Yukon XL
Post by GoldenBullet »
2002Bonneville wrote:Hopefully you can pick it up for fairly cheap - I bet the wheels alone could easily fetch near $1000 if you cleaned them up. If you do end up winning though, I'd take it to a mechanic anyways just to get confirmation as to whether or not there is chassis damage. That way at least you know for sure it would be a part-out car.
More like $400-500. And the wrinkle on the top of the driver's side quarter panel is enough to make it not worth it to me, at least to try to repair it.
-Matt
The whole rear end of that car is tweaked. No way is it worth fixing unless you own a frame repair shop.
Wheels are probably worth $750 to the right buyer. I'd say $600 would be my max on the car, it's a lot of work to tear one down and sell the parts, plus the hassle of shipping, etc.
repinS
Moderator
Moderator
Post by repinS »
00Beast wrote:Wheels are probably worth $750 to the right buyer. I'd say $600 would be my max on the car,
Only if those tires are still usable.
