need help fast wont start
trf_ssei
- GXP Member
- Year and Trim: 1998 bonneville SSEi
Hey guys been a while since ive posted or been on the computer period, but anyways here's my problem. The car has been running pretty rough for quite a while. but always started good and its something to drive. but i pulled out of a parking lot today and stepped it down hard and the car was surging and missing(sounded like) and all of a sudden died. i tried restarting it several times and the first couple times it fired but wouldn't start, after that it wouldn't even fire at all. i have pressure at the rail, all 3 coils were just replaced 2 weeks ago and it was a big improvement in run-ability. I don't know where to look next. the car has 380 000 km on it and will soon be retired but i need it for at least another 6 months. what else can i look at or test or anything. please help. thanks in advance.
If it were quick and easy everyone would be doing it!
- flatlander745
- GXP Member
Re: need help fast wont start
Sounds like it might be an injector, if you have dvm check resistance on them if you can get to the connectors. They should probably all be around 14.0 ohms +/- 1.0.
trf_ssei
- GXP Member
more to add, i have spark and fuel. I think my plugs are fouled now causing it not to fire at all. its to dark now to check the resistance on the injectors, although i don't see it completely stalling from one or even two injectors . i wont be able to check anything until after 3 tomorrow but i am open to as many suggestions as possible until then.
Hold the accelerator to the floor while starting. If it starts, let off the accelerator. If it starts, see if it will idle at all.
trf_ssei
- GXP Member
i tried holding it to the floor and nothin, not even a burp. battery died now so done testing for tonight, but im testing as soon as i get suggestions and i appreciate everyone's prompt responses. keep em comin..lol
- flatlander745
- GXP Member
One crapped injector will shut down the system. If you find a bad reading on one, unplug it and it will run...on 5 cylinders if necessary.
trf_ssei wrote:more to add, i have spark and fuel. I think my plugs are fouled now causing it not to fire at all. its to dark now to check the resistance on the injectors, although i don't see it completely stalling from one or even two injectors . i wont be able to check anything until after 3 tomorrow but i am open to as many suggestions as possible until then.
trf_ssei
- GXP Member
I'll try that but i should also add that i checked for injector pulse on cyl #3 via the 194 bulb method and it was lighting fine, does that change anything?
flatlander745 wrote:One crapped injector will shut down the system. If you find a bad reading on one, unplug it and it will run...on 5 cylinders if necessary.trf_ssei wrote:more to add, i have spark and fuel. I think my plugs are fouled now causing it not to fire at all. its to dark now to check the resistance on the injectors, although i don't see it completely stalling from one or even two injectors . i wont be able to check anything until after 3 tomorrow but i am open to as many suggestions as possible until then.
Just means that injector is getting current. One injector will not cause the whole engine to not run, but it will run like CRAP.
- flatlander745
- GXP Member
On the early 90's 1st generation gm a start/stall no start would be a single injector..... a bad injector killed the whole circuit. Not the same on these years?
00Beast wrote:Just means that injector is getting current. One injector will not cause the whole engine to not run, but it will run like CRAP.
Nope, not the same.
trf_ssei
- GXP Member
still wont start. im goin to try some ether and ill post back results.
trf_ssei
- GXP Member
another no go with the ether, injectors are all 12ohms. i was thinking maybe cam sensor or skipped a tooth on the timing chain, but it still turns over like normal i don't know im just gettin frustrated.
- flatlander745
- GXP Member
Can you check for voltage from the crank and cam sensor(s) at the ignition module while someone turns the ignition? Wires may be Crank-Yellow and Cam-BRN/WHT.
Have you checked for spark at the plugs? Do the lamp check on the injectors and a fuel pressure check.
- dpcookson
- SSE Member
- Year and Trim: 1982 Chevy S10
2003 Ford Focus
1996 VW Jetta - Location: Jarvis, Ontario Canada
"From earlier posts in this thread"
trf_ssei wrote:... i have pressure at the rail......
...i have spark and fuel......
...i checked for injector pulse on cyl #3 via the 194 bulb method and it was lighting fine......
Dale
How was the spark checked? At the plugs or coils. All of them or just one. Was the fuel pressure checked with a gauge or just by pressing the shrader valve.
Also check connections and harness to cam nd crank sensors and check connectio. To ICM.
- Archon
Also, try disconnecting the MAF and see if it will then start.
trf_ssei
- GXP Member
I checked the spark at the plug, just one. And i just pressed the shrader valve for fuel pressure. but i pulled the three front plugs and they were all fuel soaked so i changed all the plugs and tried ether again, nothing didn't even fire.
myfirstbonnie wrote:How was the spark checked? At the plugs or coils. All of them or just one. Was the fuel pressure checked with a gauge or just by pressing the shrader valve.
trf_ssei
- GXP Member
Tried that. Same thing not even firing.
Archon wrote:Also, try disconnecting the MAF and see if it will then start.
trf_ssei
- GXP Member
How do i do that just use a common ground and test each wire with my positive lead?
flatlander745 wrote:Can you check for voltage from the crank and cam sensor(s) at the ignition module while someone turns the ignition? Wires may be Crank-Yellow and Cam-BRN/WHT.
