That looks bad. If you've confirmed that it's not coming from the elbow, that just leaves the LIM gasket, right?
WHITE WHINE - 1992 SSE Supercharged 236.26 ci (.040 Over) 15.090 at 90.2 MPH on old engine w/ slipping trans & melted O2 sensor - Gen 3 M62 and matching TB, Gen 2 Pully, Zillamotorsports Ported LIM, YT 1.72 Roller Rockers, SII FPR & Injectors, Hypertech Thermomaster chip w/ 160 Thermo, TransGo Shift Kit, Infinity/Pioneer Speakers & a 10" Alpine Type R Sub, all the watts, 140 amp Alternator, Ricepipe CAI w/ heatshield, Pilot Angel Eye Foglights, Clear Corners, '02 17" Chrome Bent 5's, Magnaflow F-Body Muffler and Hi-flo Cat, Ceramic Coated Ported Exhaust Manifolds, Fan Override, Monroe Reflex struts, red calipers 2009 G8 GT - Sport Red Metallic, loaded, SOLO Axlebacks, Rotofab Intake, Tuned, autodim mirror, removed intake manifold cover, HSV GTS triple gauge pod, two tone red-hot shifter and HSV SuperSport steering wheel, GXP rear sway bar and diffuser, 3.45 diff and various Camaro suspension bits, LED Taillights
That should be listed in the techinfo article on changing the intake gaskets. It's hard to tell from the pictures, but the leak appears to be coming from where the elbow goes into the LIM. Even so, if you can, may as well take care of everything by doing the intake gaskets. You could go to the dealer and get the gasket there, or order it from Intense-Racing.
Edit - The link didn't provide any product info., and the second design is just whether or not the end cap gaskets have a rubber alignment nub. Felpro is now making a metal framed gasket.
J Wikoff wrote:That looks bad. If you've confirmed that it's not coming from the elbow, that just leaves the LIM gasket, right?
Well after 11 years, the plastic decided it wasn't going to put up any of that temp-changing nonsense and it was failing bad. I had a garage guy look at it and when he got the alternator off and gave it a tug, it crumbled. He spent most of his time taking out chunks and removing crap inside the water pump passages.
Verdict: $70 and both plastic elbows later, no leak.
I am now planning a trip to the old man's place to do the LIM anyway.
When you do the LIM gaskets, replace them again, lol. They're only like $8 and they like to break while coming out.
Bye Bye: RIP sandrock
