just got it
wjcollier07
- Year and Trim: ____
Re: just got it
And, in addition to that, some 10w-40 wouldn't hurt to buy a little time as well. Definitely don't go any higher than that, but a heavier oil should help slightly.
John
bigunit2011
- Year and Trim: 92 bonnie
Re: just got it
ya it actually does when i am going to school it dont start moven till it hits about 180 degrees roughly
- Bugsi
Re: just got it
We ran 20W-50 in our old high-mileage 1988 Grand Prix SE (2.8L V6), and that kept it limping along for maybe 5 years before it blew a head gasket. (It was genuinely low oil pressure when idling, the engine was very worn out.)
`05 Mercedes S500
`05 Mercedes S500
bigunit2011
Re: just got it
hmmm i only got like 163k on
- Bugsi
Re: just got it
It all just depends on how it was used/abused. My car has around 160K on it, and it's still like it's brand new. But other cars can be trashed by 160K if not properly cared for and maintained.bigunit2011 wrote:hmmm i only got like 163k on
`05 Mercedes S500
`05 Mercedes S500
robertccach
- Year and Trim: 1998 Ssei
Re: just got it
Um,did you read the post where I said just change the oil filter?Its alot cheaper then all the other stuff.
01bonneSC
Re: just got it
Just curious to what filter you do have on it, bigunit.
bigunit2011
Re: just got it
its a microgaurd i think how you spell it
bigunit2011
Re: just got it
thanks man that also might be a problem lol
1995BonnevilleSE
- LE Member
- Year and Trim: 1995 Pontiac Bonneville SE 3.8 liter
Re: just got it
If your oil pressure gauge is bouncing up and down in idle first change the oil. Make sure you examine the oil check for coolant also use a magnet to check for metal shavings. This indicates a major problem most of the time anything from a blown oil ring to blown head gasket or possibly a sticking valve
bigunit2011
Re: just got it
all those dont seem that bad i mean perhapas the sticking valve but other then that the valve cover casket aint bad i already changed that
