Egg in Radiator
Bonneville92V688
Year and Trim: ‘12 Jeep Grand Cherokee Overland Summit
Re: Egg in Radiator
Post by Bonneville92V688 »
trigga_b wrote:What size is the sse radiator 1" or 1-3/8 and does it have the eng. oil cooler?
Pull the plastic shroud (the one with all the stickers on it) off the radiator (remove the top bolts for the fans too or it won't come off) and measure the core. You will know if you have a oil cooler, just look on the driver's side of the radiator. If you have 2 fairly large pipes going in, you have the oil cooler.
1996 Thunderbird LX - 3.8
trigga_b
Year and Trim: '00 Buick Park ave Ultra
Re: Egg in Radiator
Post by trigga_b »
Sorry, I ask I lot of newbie questions, but I just like to be reassured. I figure the 1-3/8 could fit.
93' Purple SE (Totaled)
92' White SSE (MIA)
06' Charger R/T
08' Altima Coupe
00' Buick Park Ave Ultra
wjcollier07
Year and Trim: ____
Re: Egg in Radiator
Post by wjcollier07 »
Yeah, it'll fit. Thicker cores are better in general.
John
Bigerik
Year and Trim: 2004 Bonneville GXP
1997 Oldsmobile LSS L67 - SOLD
Re: Egg in Radiator
Post by Bigerik »
X3 on the Bars. If you have to use something, it is the stuff to use.
Back in when Aston martin still built quality cars (not just upmarket Fords) every new V-8 would leave the factory with a can of "Bars" in it....
2004 GXP - Greystone and stock
95 Oldsmobile 98 L36. 180 degree thermostat. Tru-Cool tranny cooler. Touring Sedan wheels. FE3 springs. Urethane End Links. Magnaflow Cat 94006 -> Soon to be replaced by something that works. WAI. Ported and polished LIM.
Mods coming soon - . Touring Sedan seats. TS Sway bars. - Sold
97 Oldsmobile LSS L67 - Stock. For now. - Sold
Boreas
Year and Trim: 1993 SE
1996 SSEi
1997 SSEi 40th
Re: Egg in Radiator
Post by Boreas »
Roadtech195 wrote:
Boreas wrote:They DID try that out in Mythbusters and it turned out to be plausible, it did stop the leak in their test. However this is a temporary solution in the case of an emergency if you are in the middle of the road and need to get home. Obviously not a permanent solution.
Linky dinky.
Um, how many people carry eggs with them on long drives? raise your hands... anyone?
Seems like it would be a good idea if you popped a radiator near a chicken farm but you would still have to steal an egg without getting shot by the farmer. Just fix it the right way and you will never have to post about using an egg for repairs ever again. :roll:
You need to chill out. It wasn't realized until later in the thread that the authoring poster was serious about sticking an egg in the radiator. To me it was a hypothetical question that got its answer:
Can you stop a leak with an egg? Probably yeah.
Now is it a good idea? Hell no.
Nevermind the semantics of actually finding an egg wherever one may be...
If you are going to attack someone, attack the authoring poster and not me. Thanks.
1993 Bonneville SE "Old Ironsides" 244,xxx - Junked.
1996 Bonneville SSEi "Double Trouble" 164,xxx - Stock
1997 Bonneville SSEi 40th "Purple Spaceship" 204,xxx - Aeroforce Interceptor, B&M 70264 Trans Cooler, Intense FWI, High-Flow Feline, non-Bose head unit w/ 5 band, Alpine 6x9's, 3.5 MPS, SD Headers, rear disc brake conversion. Future: 1.9 Rockers
1997 Buick Park Avenue "Blue Floaty Thing" 124,000 - Daily Driver/Winter Beater
Re: Egg in Radiator
All right. We have a farm truck, a 67 chevy 4x4, and i put an egg in the radiator because it had a pinhole leak. It held for 3 days on the farm without leaking, and we used it quite a bit.
Answer: Yes, it will stop a small leak. However, it is not a permanent solution, and only works on smaller leaks, not a busted tube or anything else, just a patch to keep all of your fluid from leaking out while on your way home from the grocery store (hence the Egg) or anywhere else.
wjcollier07
Year and Trim: ____
Re: Egg in Radiator
BUT
the problem is that you have to VERY comprehensively flush the system once you've contaminated it with...an egg.
John
blubyu
Year and Trim: 2004 GXP
Re: Egg in Radiator
Post by blubyu »
My cousin put pepper in his 76 trans am. It worked, but his car smelled like a pot of soup.
chopper442
Year and Trim: 1997 SSE
Re: Egg in Radiator
Post by chopper442 »
Will it work ...maybe...I`d save the egg for the bacon and fix`er right!
1997 SSE - Bright White -Gutted box, Overlays, GTA vents, cleared corners, calipers..so far.
Roadtech195
Year and Trim: 2007 Grand Prix GT
Re: Egg in Radiator
Post by Roadtech195 »
Boreas wrote:
Linky dinky.
I should have specified that my reply of " Just fix it the right way and you will never have to post about using an egg for repairs ever again." was meant for the authoring poster and not Boreas. My deepest apologies. I deserve a :buttkick:
2007 Grand Prix GT L32
Poly endlinks, swaybar bushings and dogbone bushings. Drop in high flow air filter. Its a start!
2009 Mitsubishi Eclipse GS (project BlackSheep) Bone stock for now, 5 spd and fun as hell! (Gf's Ride)
1996 Pontiac Bonneville SE Gone but not forgotten
1997 Dodge Ram Sport 4x4 5.9L The Beast!
Ol' Timer
Year and Trim: 1991 Olds 88
Location: New Jersey - Most of Our Elected Officials Have Not Been Indicted
Re: Egg in Radiator
Post by Ol' Timer »
I wonder......if you put egg in the radiator to stop a leak, and you find that it's the Head Gasket that is leaking, does the exhaust have that rotten egg smell??? :roll:
2006 Salsa Vibe - Auto - Side Curtain Air Bags - ABS - Vehicle Stability Control - Tunes No Moon - Monotone - Preferred Package - Slate Cyper Cloth - Steelie Wheels
2002 Snap Orange Beetle - Auto - Turbo
1991 Dark Garnet Red Oldsmobile 88 - Donated to Science
Roadtech195
Re: Egg in Radiator
Then you may think the cat is shot :laughing3:
Boreas
1996 SSEi
1997 SSEi 40th
Re: Egg in Radiator
Post by Boreas »
Roadtech195 wrote: I should have specified that my reply of " Just fix it the right way and you will never have to post about using an egg for repairs ever again." was meant for the authoring poster and not Boreas. My deepest apologies. I deserve a :buttkick:
Its alright. Have a beer on me. :beer:
