Egg in Radiator
trigga_b
- Posts like an LN3
- Year and Trim: '00 Buick Park ave Ultra
Egg in Radiator
Has anyone ever tried this? Is it safe to do? I've read somewhere that it's better than using additives to stop radiator leaks.
93' Purple SE (Totaled)
92' White SSE (MIA)
06' Charger R/T
08' Altima Coupe
00' Buick Park Ave Ultra
92' White SSE (MIA)
06' Charger R/T
08' Altima Coupe
wjcollier07
- Year and Trim: ____
Re: Egg in Radiator
Just. Replace. The. Radiator.
Fix it right, or you'll regret it later.
John
LakevilleSSEi
- Recognized Vendor
- Year and Trim: 96 Audi A6 Quattro
- Location: Lakeville, Minnesota =MWBF '05 SURVIVOR= =CEBF '06 SURVIVOR= =August '06 COTM=
Re: Egg in Radiator
Depending on the issuse.....a tin or two of Copenhagen can plug a hole up temporarily...
I've NEVER heard of the egg though.
IIRC Pepper works too.
1995 SSEi - Traded to Adam Marcum
1998 SLE - Traded for my Dodge
2003 Dodge Ram 2500 Laramie - Sold
1996 Audi A6 Quattro
I used to be cool......Then I traded my Bonne's.
- 2000Silverbullet
- Retired Gearhead
Re: Egg in Radiator
Now is your opportunity to replace the rad with a thicker more efficient one. Take it to a rad specialist and have them do it right. Shouldn't cost you more than $200.
- GoldenBullet
Re: Egg in Radiator
i wouldnt try an egg... something that cooks in boiling water doesnt sounds like a good idea to me.
-Matt
- Boreas
- Posts like an L36
- Year and Trim: 1993 SE
1997 SSEi 40th - Location: Chi-Town
Re: Egg in Radiator
They DID try that out in Mythbusters and it turned out to be plausible, it did stop the leak in their test. However this is a temporary solution in the case of an emergency if you are in the middle of the road and need to get home. Obviously not a permanent solution.
Linky dinky.
Linky dinky.
1993 Bonneville SE "Old Ironsides" 244,xxx - Junked.
1996 Bonneville SSEi "Double Trouble" 164,xxx - Stock
1997 Bonneville SSEi 40th "Purple Spaceship" 204,xxx - Aeroforce Interceptor, B&M 70264 Trans Cooler, Intense FWI, High-Flow Feline, non-Bose head unit w/ 5 band, Alpine 6x9's, 3.5 MPS, SD Headers, rear disc brake conversion. Future: 1.9 Rockers
1997 Buick Park Avenue "Blue Floaty Thing" 124,000 - Daily Driver/Winter Beater
- GoldenBullet
trigga_b
- Posts like an LN3
Re: Egg in Radiator
What type of radiator should I look into getting? The fins on this radiator are still in good shape. It's leaking from the passenger fin area. A shop said they'll repair it for 35 bones. I really can't put too much money into the SSE though because I'm working on the SSEI.
92' White SSE (MIA)
06' Charger R/T
08' Altima Coupe
92' White SSE (MIA)
06' Charger R/T
08' Altima Coupe
- TenGHz
- Posts like a Northstar
- Year and Trim: 2005 GXP
Re: Egg in Radiator
I saw it too. Definitely NOT a permanent solution. Fix it right or you will regret it!Boreas wrote:They DID try that out in Mythbusters and it turned out to be plausible, it did stop the leak in their test. However this is a temporary solution in the case of an emergency if you are in the middle of the road and need to get home. Obviously not a permanent solution.
Linky dinky.
-Joshua-
- Bugsi
- Year and Trim: (RIP 10/31/15) 1997 SE
05 Mercedes S500 4Matic - Location: Sunnyvale, CA
Re: Egg in Radiator
You can get a shop to repair your radiator for $35, and you're here asking us what you should do?
If your radiator is in otherwise good condition and won't blow up from a pressure test, then spend the $35 and get your radiator fixed. If you can't afford that, learn how to solder and fix it yourself. It really isn't that hard. Of course, you'll spend more than $35 on tools, time, and equipment to fix it yourself, but you'll have learned a useful skill and you'll have the tools to repair a radiator in the future.
If your radiator has a leak because it is in generally overall bad shape, then any time or money spent on it is time or money wasted. In that case, you buy a radiator and install it.
I saw the Mythbusters episode too, and yes, an egg stopped a very tiny leak. But how long will it last? I personally don't like the idea of putting ANYTHING in my cooling system other than coolant and water. My wife's '01 GP GT had a minor leak at some fitting, and the General Motors service bulletin actually called for adding stop-leak pellets to the cooling system, and that's what my dealership did. It stopped the leak. I'm still furious about it. But if you're serious about putting an egg in your radiator, maybe phone a dealership and ask them what kind of stopleak pellets they use.
`05 Mercedes S500
`05 Mercedes S500
- Bugsi
Re: Egg in Radiator
(I hate replying to my own post, but to do it anyway. . .)
I learned about fixing cars because my father was both cheap, and terrible at fixing anything. If the radiator leaked, he'd buy stopleak and dump it in. If it leaked again he'd buy more stopleak and dump it in. When the radiator eventually blew up from a pressure test, he'd buy a used radiator for half price from a junk yard. When that would fail after the warranty was out, I'd eventually go buy a new radiator for full price.
Now add up the cost of all of that in terms of time and money spent on stopleak and used radiators, and compare to just buying a new radiator once and fixing it right the first time.
Since *I* was the source of labor to remove and install the original and junkyard radiators, it was immediately obvious to me that there is both a financial and time benefit to fixing things correctly the first time around. Put simply, you'll just spend more money and waste more time trying to band-aid a problem instead of fixing it correctly the first time around.
There is a time and a place to use band-aid solutions. That time and place is when you need to limp your vehicle to a location where you can fix it properly. If that's not the case, then just fix this correctly the first time around and thank yourself later.
-Mark
-Mark
`05 Mercedes S500
`05 Mercedes S500
- BlackHawk99
- Senior Moderator
- Year and Trim: _
Re: Egg in Radiator
To reitterate what Mark said in my own terms that I often say.....
"I can't afford cheap parts" and "I can't afford cheap tools".
bonnevillain
- Year and Trim: 2002 SLE
Re: Egg in Radiator
yeah, pepper will work temporarily i've used it on my motocross bikes.
- Troyport
- Posts like an LN3
- Year and Trim: 1993 Bonneville SE, restoration finished
Re: Egg in Radiator
Cheap parts, cheap tools.. depends on the application. I have a set of Harbor Frieght impact sockets, 1/10th the cost of snap-on, and for the amount they get used, a much better buy. Now if I was supporting my family with those tools, I'd get the best.
When I rebuilt the tranny for the bonny project, I did not replace all the hard parts that I would have in my daily driver. Same reasoning. I've used the band aid stop leaks, but not in a car I planned on keeping. I'd shy away from an egg, might put a stop leak in MY daily driver, depending on the leak.. but my wife's van would get only new top-quality parts, I don't want her broke down on the side of the road with my girls.
However, my father in law has some type of special god looking after him, He'll find some kind of clearance shelf additive and it will work for years. My favorite story was his Bronco 2, it had over 200K on it, piece of junk. Tranny was shot, he ran it out of fluid, little bits of metal goodies in the pan, fluid was black and stinky.. He filled it up with bargain basement fluid and added a can of transfix he found on the clearance rack of a drugstore, and I'll be *dang* if he didn't drive it another 30K like that. He even took it on a cross-country trip. Incredible. Mike
- Roadtech195
- Posts like an L36
- Year and Trim: 2007 Grand Prix GT
Re: Egg in Radiator
Linky dinky.
Um, how many people carry eggs with them on long drives? raise your hands... anyone?
Seems like it would be a good idea if you popped a radiator near a chicken farm but you would still have to steal an egg without getting shot by the farmer. Just fix it the right way and you will never have to post about using an egg for repairs ever again.
2007 Grand Prix GT L32
Poly endlinks, swaybar bushings and dogbone bushings. Drop in high flow air filter. Its a start!
2009 Mitsubishi Eclipse GS (project BlackSheep) Bone stock for now, 5 spd and fun as hell! (Gf's Ride)
1996 Pontiac Bonneville SE Gone but not forgotten
1997 Dodge Ram Sport 4x4 5.9L The Beast!
Ol' Timer
- Posts like an L67
- Year and Trim: 1991 Olds 88
- Location: New Jersey - Most of Our Elected Officials Have Not Been Indicted
Re: Egg in Radiator
I remember using this stuff as a quick cheap fix in my old '67 Chevy Nova. I was amazed that it plugged up the pin hole leak in the radiator. I never lost sleep over it and I never had a cooling problem with it throughout the life of that car.
2006 Salsa Vibe - Auto - Side Curtain Air Bags - ABS - Vehicle Stability Control - Tunes No Moon - Monotone - Preferred Package - Slate Cyper Cloth - Steelie Wheels
2002 Snap Orange Beetle - Auto - Turbo
1991 Dark Garnet Red Oldsmobile 88 - Donated to Science
- radomirthegreat
- Year and Trim: 1994 SSEi 1999 SLE
Re: Egg in Radiator
:sad5: I'm still fine!2000Silverbullet wrote:Now is your opportunity to replace the rad with a thicker more efficient one. Take it to a rad specialist and have them do it right. Shouldn't cost you more than $200.
I've heard of both pepper and eggs being used, but it's not something I'd ever put into a radiator. That may plug a hole, but your water pump will slosh it around too. I was down and out with a large radiator hole out of nowhere just before work about a year and a half ago, and my friend and I worked on my car while it was raining under the shelter of a gas station roof. I didn't use any of those awkward fixes. Instead, I bought a new radiator and dealt with the horrible cost. It's worth it, though.
94 SSEi - Project car
99 SLE - Tuned with different parts and such
85 Porsche 944 - Daily driver
68 Chevy C-10 - Free truck! Needs parts.
Barry
- Posts like an L27
- Year and Trim: 1999 SSE
Re: Egg in Radiator
x2 on the Bars' Stop Leak. It has been around for decades and I've know many shops that have used it. Still, for $35.00, I wouldn't even bother to open the hood and remove the rad cap. I'd take it in and have them fix it.
1999 SSE. 112k, Cleared Corners, Mobile 1, Energy Suspension endlinks. Ported and Polished LIM, NGK TR-55 Sparkplugs, 180 drilled Intense stat, Flow matched injectors, Intense FWI, Intense PCM, MagnaFlow Cat.
b18jason
- GXP Member
- Year and Trim: 99 Bonneville SLE,
Re: Egg in Radiator
my brother has a caravan with the 3.3 and 2 years ago the head gasket started leaking bad externally. Just on a whim and because my brothers a college kid with no cash, we put barrs stop leak in it and it worked. He drives from his college in New York to Mass every other weekend and it hasn't leaked a drop and its been over 30,000 miles
trigga_b
- Posts like an LN3
Re: Egg in Radiator
What size is the sse radiator 1" or 1-3/8 and does it have the eng. oil cooler?
92' White SSE (MIA)
06' Charger R/T
08' Altima Coupe
92' White SSE (MIA)
06' Charger R/T
08' Altima Coupe
