is this normal?
RookieSSei
- SSE Member
- Year and Trim: 2002 SSEI
ALL STOCK (FOR noW)
is this normal?
Okay sometimes when I start my car the rpm hand jumps right to 2000rpm if I put the car n gear I get a hard thrust like the engine is about too by jump out of the car but if I wait a couple sec and let it drop to under 1500 It shift fine ? Also I noticed once I put it in gear I can coast without giving it gas 500 to 1000 feet no gas what is causing this ?
Re: is this normal?
Sounds like you are pretty rough on your car!
Everytime you start the car, wait for the idle to smooth out before putting it in gear. Ususally 5-10 seconds. NEVER put it in gear at 2000 RPMs.
It is normal for the car to coast if youi don't hold the brake.
bonnevillain
- Year and Trim: 2002 SLE
Re: is this normal?
if you are coming from an older car, especially carbureted ones, the ease with which these cars coast is strance
RookieSSei
- SSE Member
ALL STOCK (FOR noW)
Re: is this normal?
well no not all ruff this all started after i replaced the motor it's been down hill ever since . the car really has not been the same and it's hard to pen point because when i try to take the car in and show the shop it wont do it
Re: is this normal?
First, unplug the IAC with the engine off. Plug it back in and then start the car. Also, check the TPS. It should be around .4 or .5 volts with the throttle closed and should increase to around 5 volts with the throttle fully open. With an idle issue, you will be most concerned with the .4 volts at closed throttle.
RookieSSei
- SSE Member
ALL STOCK (FOR noW)
Re: is this normal?
would this contribute too ruff idle random high idle at start and would this set a code ?
RookieSSei
- SSE Member
ALL STOCK (FOR noW)
Re: is this normal?
Bump would tps give a code?
- Archon
Re: is this normal?
The IAC shouldn't cause a rough idle, but a vacuum leak could. Have you checked for a leak? It could affect idle speed, too. While there are codes that could be set for a bad TPS, it doesn't always set one.
RookieSSei
- SSE Member
ALL STOCK (FOR noW)
Re: is this normal?
yeah i did i dont know whats wrong with this car somedays it dirves perfect shifts fine . then somedays it sucks i feel like it's not the trans it's been rebuild 3x i think it's something thats connected with the trans like a sensor or something. it bucks under load wot mostly during wot and when i turn corners like braking and then giving it gas . I can trigger it like clock work a sudden slow down at a light then give it some gas and it bucks or shift hard into gear . I just dont know somebody told me it could be the tps going bad idk i just want this fixed
- spidey3479
- Posts like an L27
- Year and Trim: 2001 SSEI, 2004 SLE
Re: is this normal?
Sounds like a job for a really good honest mechanic. Do you trust the shop that did the work? If not then just take it to the nearest dealership and let them give it the once over. Sounds like you have more issues than you can diagnose here w/o someone testing and being there at the vehicle. The bestest mostest importante tool you could ever have is a good honest mechanic.
1988 SSE-Gone but not forgotten.
2001 SSEI-304,572 miles, 3.5 Pulley, Intense PCM, Intense FWI Spectre filter, 160 tstat, ngk iridiums, belden wires, Silverstars-high and low beam, rebuilt tranny, shift kit, cooler, Dex VI fluid, replace the rear compressor and lines and level sensor, Monroe air shocks in back, FE5 struts and Moog strut mounts, Moog stabilizer bars, AC\Delco control arms.
2004 SLE-Stock, 195,000 miles,oldest son's baby now
2000 Ford Ranger-Stock, 352,000 hard, pizza delivery miles, new control arms (upper and lower), new(used) tranny
- Pontiacdad
- Retired Gearhead
- Year and Trim: 2000 SSEi
Re: is this normal?
Does the service engine soon light come on?
If so what codes does it show?
Bone Evil
Mods: Tog Headers, cat delete, Al 104's gapped .050, 1.9 rockers, 105 springs,
Intense FWI, DHP Power Programmer PCM, Intense tranny with gen2 lsd,
Aeroforce scan gauge, Clear front and back, N* TB & LQ4 Maf,
Hoosier slicks, ZillaMotorsports P/P GenV & LIM
Pisco_Paul wrote:Every time you pat my head, you pat a piece of my valve retainers.
RookieSSei
- SSE Member
ALL STOCK (FOR noW)
Re: is this normal?
yeah i got like p0332 knock sensor back low fuel level sensor
