1994 Bonnie SLE
Concurrent malfunctions: Torque converter never locks, cruise control doesn't work, shifter safety lock solenoid clicks on every brake pedal press/release even while driving (I never noticed that before so I think that is abnormal).
All the above failed at once, came back one day, haven't worked since. Any ideas as to what the problem may be?
Tony
No torque converter lockup or cruise control, shifter lock..
'94 SLE, 169k: Black grill from a '97 (not shown). Raybestos Advanced Technology rotors and pads. Factory trans cooler from an SSEi. Silverstar Ultra high and low beams.
- RJolly87
Re: No torque converter lockup or cruise control, shifter lock..
I was thinking stuck brake switch until you mentioned the solonoid, but then I wonder how the vehicle, electrically anyway, knows where the gear selector is. Is it through the Neutral Safety switch?
~Randall~
I finally got in under the hood to check things out (Cuz someone told me my brake lights were not working!). The neutral safety switch is sensitive: it makes a difference whether is tightened down or not. My "field" fix of the switch gave it different characteristics and standard adjustment does not apply. And I didn't check the brakelights before I put away the tools (they worked while adjusting though!). I readjusted the switch and now have brakelights and torque converter lockup after a new adjustment procedure given the situation. I still have a cruise control inop problem though (I think, I test drove with the vacuum release line off tonight, but I don't think that would prevent the cruise control from activating).RJolly87 wrote:I was thinking stuck brake switch until you mentioned the solonoid, but then I wonder how the vehicle, electrically anyway, knows where the gear selector is. Is it through the Neutral Safety switch?
(Aside: note that my '94 has 2 switches at the brake pedal: tcc/abs and stoplight (as far as I can tell by diagnosis)).
Edited by Admin. If you post here in the public domain, you give up your 'copyright'. The only copyrights legally honored on public forums are those owned by other entities that are non-members and did not willingly post their data/info here personally.
- sandrock
- Retired Gearhead
What the fook is this?Tony94 wrote:
(c) 2009 by poster. All rights reserved.
BTW...neutral safety switch adjustment has absolutely nothing to do with brakelights. Not even on the same circuit.
I assure you that you are wrong. The neutral safety switch incorporates the backup light switching. I posted in 1994, yes? I have a 1994 Bonnie. It DOES TESTABLY control the backup lights. (This is an example of a NOISE post that would be eliminated on a knowledge-based site, btw).
- sandrock
- Retired Gearhead
Cool your jets dude. I mentioned NOTHING about back-up lamps. I mentioned BRAKE lamps in my last post, to correct what you stated in your first one.
- willwren
- Retired Admin
User banned for multiple issues. Move along folks. Nothing to see here.
