It is currently Wed Oct 08, 2025 6:56 am
Post new topic Reply to topic  [ 3 posts ]
PostPosted: Tue Aug 03, 2010 9:25 pm
I have a 2002 SLE withh electronic climate control. The fan motor is not working but the fan level indicator shows fully on. After driving a bit the fan does come back on and works like it is supposed to. This has occurred 3 times now and since I live in a hot climate - South Carolina - I need to know what is up with this.
Robert Flanagan
PostPosted: Sun Aug 08, 2010 6:28 am
This sounds like the blower motor itself is not connecting electrically. When your car hits a bump or moves it causes the rotor inside the fan motor or the connections in the leads outside to make contact and it starts running. A good check is when it's not running and the key is ON, tap your foot up against the bottom of the blower motor part of the housing just to the right of the driveline tunnel. The blower will start.
Three screws and a connector and an air tube that cools the rotor. Check the connector for burned contact. My 03 had brushes inside the motor that didn't make contact; the one brush was sticking in its slide.
I used a replacement motor from Autozone because they stock them. Other box stores were happy to order them in for delivery in two days. I did have to go to another metro Autozone because only two stores actually had not sold theirs.
PostPosted: Sun Aug 08, 2010 8:59 am
I have seen a few in the 2000+ crowd (including our '03 SSEi) have a loose connection at the blower motor, ours was loose enough to start melting the connector itself. I had to remove the wires from the plug and crimp them down better to get a better connection on the blower motor.
There are no new unread posts for this topic. No interior light (from time to time) when key is out
laimisl
Tue Aug 18, 2009 9:41 pm
laimisl View the latest post
There are no new unread posts for this topic. gauges not working
Bill in Florida
Wed Jan 10, 2018 12:10 am
dougtoth View the latest post
There are no new unread posts for this topic. Heat not working, 97 SSE.
ga93sle
Wed Dec 05, 2012 9:16 pm
ga93sle View the latest post
There are no new unread posts for this topic. DIC and compass not working
blackmagic94
Thu Apr 16, 2015 2:44 pm
blackmagic94 View the latest post
There are no new unread posts for this topic. cooling fan not working
westernkansas
Tue Aug 18, 2009 4:16 pm
westernkansas View the latest post
Users browsing this forum: No registered users and 8 guests
