trouble for bonneVille SSEi 1992 http://www.pontiacbonnevilleclub.com/forum/1992/topic7734.html |
Page 1 of 1 |
Author: | tlig [ Thu Dec 11, 2008 4:53 am ] |
Post subject: | trouble for bonneVille SSEi 1992 |
Hello all In advance sorry for my bad english, i'm from Russia. In Russia has no BonneVille club, therefore writing the this forum. I'm have next trouble: Electro Adjustment of seats not work. More precisely work only button. , other button not work. What to do? Whether it is possible to move sitting manually? |
Author: | LeSabre in Buffalo [ Thu Dec 11, 2008 8:02 am ] |
Post subject: | Re: trouble for bonneVille SSEi 1992 |
Welcome! Sounds like a bad switch. And assuming they kept the same or similar seat gizmo from 1992 to 1999, then there's no way to move it manually. |
Author: | crash93ssei [ Thu Dec 11, 2008 9:54 am ] |
Welcome to the forum!! Do any of the three switches on the bottom work? If those don't work either, it could be a locked up compressor on the bottom of the passenger seat. Don't forget to check for blown fuses and power to the compressor first though. |
Author: | RJGill84 [ Thu Dec 11, 2008 10:06 am ] |
Those seats work on compressed air?!? |
Author: | crash93ssei [ Thu Dec 11, 2008 10:26 am ] |
RJGill84 wrote: Those seats work on compressed air?!? yup. The lumbar and side bolsters are moved by a small compressor under the passenger side seat. |
Author: | tlig [ Fri Dec 12, 2008 12:22 am ] |
Thanks for answers!!! On this car adjustment of seats because of that does not work that the conditioner compressor is broken? Conditioner compressor not work this time, I'm replace the compressor next time. |
Author: | tlig [ Fri Dec 12, 2008 12:25 am ] |
But for me does not work also movement moving, and it does not depend probably on the compressor, safety locks all are whole. |
Author: | 93RedSled-SSE [ Tue Dec 16, 2008 11:14 am ] |
tlig wrote: But for me does not work also movement moving, and it does not depend probably on the compressor, safety locks all are whole. tlig wrote: But for me does not work also movement moving, and it does not depend probably on the compressor, safety locks all are whole. 1. Is the problem with BOTH seats (driver AND passenger)?2. Also, do you mean that the lumbar adjustments (Pneumatic) work, but not the others (non-pneumatic.. FWD, BACKWARD, TILT, etc)? If the answer to both questions is YES, then the major components could be 1. Circuit Breaker #4 on the Fuse panel under the driver side dash (this also feeds the rear defroster) 2. Seat Control Module which is under the driver seat, close to the front edge 3. The left/right side switch (not so likely) 4. Wiring to and from the seat control module with possibility of others The pneumatic functions for the lumbar and side bolsters are a separate circuit that operate the compressor which is under the passenger seat. |
Author: | tlig [ Wed Dec 17, 2008 12:12 am ] |
i'm find the reason this trouble: Two wires have closed and have lighted up. Now other problem... how to remove a casing which passes under lever AKPP? How to remove handle AKPP? |
Author: | 93RedSled-SSE [ Wed Dec 17, 2008 10:50 am ] |
tlig wrote: i'm find the reason this trouble: Two wires have closed and have lighted up. Now other problem... how to remove a casing which passes under lever AKPP? How to remove handle AKPP? That is wonderful. Not sure what AKPP is. Can you explain further? |
Author: | tlig [ Thu Dec 18, 2008 1:51 am ] |
Automatic box of a gear change. |
