It is currently Thu Jan 24, 2019 8:18 am
PostPosted: Thu Dec 11, 2008 4:53 am
Year and Trim: Pontiac BonneVille SSEi 1992
Hello all
In advance sorry for my bad english, i'm from Russia. In Russia has no BonneVille club, therefore writing the this forum.
I'm have next trouble:
Electro Adjustment of seats not work. More precisely work only button. Image , other button not work. What to do? Whether it is possible to move sitting manually?
PostPosted: Thu Dec 11, 2008 8:02 am
Year and Trim: 2012 Eco
Welcome!
Sounds like a bad switch. And assuming they kept the same or similar seat gizmo from 1992 to 1999, then there's no way to move it manually.
PostPosted: Thu Dec 11, 2008 9:54 am
Welcome to the forum!!
Do any of the three switches on the bottom work? If those don't work either, it could be a locked up compressor on the bottom of the passenger seat. Don't forget to check for blown fuses and power to the compressor first though.
PostPosted: Thu Dec 11, 2008 10:06 am
Year and Trim: 2001 Pontiac Bonneville SE
Those seats work on compressed air?!?
"SLE without the ugly" - leather, climate control, sound, 3.05 gearing, 180* t-stat, tints. http://www.gillsystems.com
PostPosted: Thu Dec 11, 2008 10:26 am
yup. The lumbar and side bolsters are moved by a small compressor under the passenger side seat.
PostPosted: Fri Dec 12, 2008 12:22 am
Thanks for answers!!! On this car adjustment of seats because of that does not work that the conditioner compressor is broken? Conditioner compressor not work this time, I'm replace the compressor next time.
PostPosted: Fri Dec 12, 2008 12:25 am
But for me does not work also movement moving, and it does not depend probably on the compressor, safety locks all are whole.
PostPosted: Tue Dec 16, 2008 11:14 am
Year and Trim: 1993 SSE (NA)
1. Is the problem with BOTH seats (driver AND passenger)?
2. Also, do you mean that the lumbar adjustments (Pneumatic) work, but not the others (non-pneumatic.. FWD, BACKWARD, TILT, etc)?
If the answer to both questions is YES, then the major components could be
1. Circuit Breaker #4 on the Fuse panel under the driver side dash (this also feeds the rear defroster)
2. Seat Control Module which is under the driver seat, close to the front edge
3. The left/right side switch (not so likely)
4. Wiring to and from the seat control module with possibility of others
The pneumatic functions for the lumbar and side bolsters are a separate circuit that operate the compressor which is under the passenger seat.
Last edited by 93RedSled-SSE on Tue Dec 16, 2008 12:29 pm, edited 1 time in total.
PostPosted: Wed Dec 17, 2008 12:12 am
i'm find the reason this trouble: Two wires have closed and have lighted up. Now other problem...:) how to remove a casing which passes under lever AKPP? How to remove handle AKPP?
PostPosted: Wed Dec 17, 2008 10:50 am
:banana: That is wonderful.
Not sure what AKPP is. Can you explain further?
PostPosted: Thu Dec 18, 2008 1:51 am
Automatic box of a gear change.
There are no new unread posts for this topic. 93 Bonneville SSEI Runs But Has Trouble Starting
FreddieVille
Thu Mar 06, 2014 12:14 pm
FreddieVille View the latest post
There are no new unread posts for this topic. 96 ssei brake warning light trouble
forcefedbucket96
Tue Jun 26, 2012 5:18 pm
forcefedbucket96 View the latest post
There are no new unread posts for this topic. Differences between 1992 SSEi and 1994 SSEi
94SilverSSEi
Sun Jan 18, 2009 5:45 pm
J Wikoff View the latest post
There are no new unread posts for this topic. 93 ssei hvac trouble. display shows fans on full but no air
focusmaniaczx3
Wed Jun 04, 2014 5:15 pm
There are no new unread posts for this topic. have a 1992 Bonneville SSE
temple1559
Wed Nov 19, 2014 9:28 pm
