It is currently Thu Sep 25, 2025 1:38 pm
Post new topic Reply to topic  [ 7 posts ]
PostPosted: Thu May 19, 2011 5:07 pm
Year and Trim: 2002 ssei
2000 ssei
1996 ssei
My 2002 ssei stalls mostly after driving on expressway and hard to re start. codes showed MAF twice changed and still. Then showed coils and coil module, changed and still stalls. What could it be. GETTING WORRIED!!!
PostPosted: Fri May 20, 2011 9:15 pm
Year and Trim: 2001 Galaxy Silver SSEi
not sure, possibly a bad IAC motor, have you cleaned the throttle body and IAC? You could also try a tap test on the PCM when its hot and see if it stalls. All the wiring looks good to the sensors?
____________
Wayne
PostPosted: Fri May 20, 2011 9:26 pm
Does it stall while travelling on the highway or after getting off and slowing down? Pull the codes and report the code numbers here and get the description from tech info.
PostPosted: Mon May 23, 2011 10:56 am
2000 ssei
1996 ssei
It stalls after getting off. It also is stalling during warm up fast idle now. It is getting worse. i already changed MAF, coils and coill module.
PostPosted: Mon May 23, 2011 1:36 pm
Is the SES/CEL on? Get the error codes pulled at Autozone or anywhere they can read the errors codes in the PCM. Even if there is no SEL/CEL lite, you could still have codes. - BC
PostPosted: Mon May 23, 2011 1:53 pm
2000 ssei
1996 ssei
It showed the MAF sensor. Later it showed coils and coil module. All changed and still the same problem.
PostPosted: Mon May 23, 2011 2:11 pm
Year and Trim: 05 Chevy 'Hoe
89 SkiDoo
Just because it showed those codes it doesn't mean that's what the problem was.
What were the code number? And give is the description of the codes.
Less off-topic than Lane's Heated Steering wheel, but yeah, back to the topic.
There are no new unread posts for this topic. 2000 SSEi stalls at idle runs rough at high RPM
MLM
Thu Jun 30, 2022 1:42 pm
MLM View the latest post
There are no new unread posts for this topic. 2002 SSEi rough idle / fuel pressure loss
Paragongx
Fri May 25, 2012 12:38 pm
redzmonte View the latest post
There are no new unread posts for this topic. 2002 Cranks but won't start/stalls
soggytoast
Thu Jan 31, 2013 4:47 pm
There are no new unread posts for this topic. 2002 LeSabre, surges and sometimes stalls P0171/P0102 faults
Louiej99
Sun May 19, 2019 11:17 am
Louiej99 View the latest post
There are no new unread posts for this topic. 2002 bonneville sle won't idle
caseyjc1
Sun Jul 27, 2008 8:09 pm
caseyjc1 View the latest post
Users browsing this forum: No registered users and 27 guests
