It is currently Tue Sep 17, 2019 1:18 pm
PostPosted: Sun Feb 24, 2019 2:51 pm
This is a revist of the issue with the my girlfriend's car. Finally got my scan tool to link (plug is worn on vehicle) and got "P0102 MAF circuit low" and "P0171 Fuel trim lean bank 1".
My guess is one is causing the other (bad MAF causing lean condition)? Have no idea if the O2 sensor (s) has been changed.
PostPosted: Wed Feb 27, 2019 3:59 pm
Start by unplugging the Maf
and see if it improves
PostPosted: Thu Feb 28, 2019 11:08 am
Ok. Will do. It's weird that it will run fine on one start cycle, and then will run like crap the next.
I'm thing it might be something as simple as a fuel filter. It also tends to do it more on a light fuel load (3/8 thank or less). Runs better with 1/2 to 3/4 tank and premium helps (I'm guessing because of the lean condition).
PostPosted: Fri May 17, 2019 10:12 pm
FIXED!
Unplugged the MAF as suggested and the sputtering and stalling stopped. Idle was a little rough.
Avoided the $20 eBay sensors and got a Hitachi MAF from Amazon for $72 ($150 in AutoZone). Took me five minutes to change it. Car runs so smooth now you can't tell it's running.
PostPosted: Sun May 19, 2019 9:45 am
good stuff!!.....just to be sure, see if the codes are gone and not a pending code......just to be sure.
PostPosted: Sun May 19, 2019 11:17 am
I'll have to hook up my scan tool. The CEL was on from the bad sensor and was obviously still on from the unplugged sensor.
The fuel mileage was down to about 9.8 MPG (city) plugged in or unplugged.
The CEL went out within a few miles before I got a chance to reset it. Fuel economy has nearly DOUBLED to 17 MPG city driving.
There are no new unread posts for this topic. Randomly surges when hot and sometimes stalls
Mr. Ultimate
Wed Jul 30, 2014 11:03 am
Mr. Ultimate View the latest post
There are no new unread posts for this topic. P0102 (Again) 2002 Bonne SSEI
Trinity
Sun Nov 11, 2012 1:20 pm
Trinity View the latest post
There are no new unread posts for this topic. 2002 Cranks but won't start/stalls
soggytoast
Thu Jan 31, 2013 4:47 pm
There are no new unread posts for this topic. 2002 ssei stalls when idle
triplessei
Mon May 23, 2011 2:11 pm
There are no new unread posts for this topic. 2002 bonneville idle miss and p0171(SOLVED)
dkc
12
2383
Fri Mar 07, 2014 12:45 pm
Archon View the latest post
