It is currently Sat Oct 11, 2025 11:49 pm
Post new topic Reply to topic  [ 2 posts ]
PostPosted: Wed Feb 23, 2011 3:51 pm
Year and Trim: 2002 SSEI
Hi,
I have a 2002 Bonneville SSEI with 104,000 miles on it.
Today my check engine light started flashing and I took it straight to Auto Zone to have the code checked.
The first code (P0302) said the was a cylinder misfire detected in cylinder number 2.
The second code (P0202) following that said there is a fuel injector circuit condition with injector number 2.
I don't think it has to do with high fuel pressure-pressure regulator or TPS and circuit failure.
I think it is either a open or shorted fuel injector(s) or open or short in electrical circuit.
It is weird how as soon as I left the automatic car wash today that this problem started.
Any ideas or things to look for that can help me with this problem?
The car idles really hard and when going from about 0-10 MPH it stutters a bit, but after that the car runs smooth. When I push the gas the check engine light flashes (misfire) and as soon as I let go of the gas the check engine light is steady.
I am hoping this will not be a major repair or cost a lot of money. Is there any chance that bad spark plugs can cause all of this?
Thank you for your help!
PostPosted: Wed Feb 23, 2011 4:43 pm
The check engine light flashing indicates a potentially catalyst damaging condition, which generally is a misfire. With the injector code, it is not likely that it is just a bad plug.
If you have a 194 or similar bulb, straighten the pins and push them in to where the wiring is on the #2 injector. Start the car and see if the bulb flashes. If it does, then the injector is probably getting the signal that it needs. If not, then you may have a wiring problem. You could also swap injectors with another one on the engine, then see if the code stays with #2, or moves to where you swapped it.
There are no new unread posts for this topic. 00 Bonneville SSEI Cylinder 1 Misfire & Strange Noise
donn188
11
3730
Thu Nov 08, 2012 7:32 am
donn188 View the latest post
There are no new unread posts for this topic. 2002 Bonneville SSEI Air Mix actuator
Bazza
Tue Jan 27, 2009 3:28 am
Bazza View the latest post
There are no new unread posts for this topic. Service engine soon light bonneville 2002 ssei
Markwashere
Mon Jan 14, 2013 10:27 pm
There are no new unread posts for this topic. How do i change water pump on bonneville ssei 2002?
Markwashere
Fri Dec 21, 2012 7:43 am
myfirstbonnie View the latest post
There are no new unread posts for this topic. Will a 2004 impala ss motor work in a 2002 bonneville ssei?
TC Ramone
Tue May 21, 2013 4:32 pm
TC Ramone View the latest post
Users browsing this forum: No registered users and 26 guests
