It is currently Wed Oct 08, 2025 8:28 am
Post new topic Reply to topic  [ 18 posts ]
PostPosted: Mon Jul 16, 2012 12:16 am
Year and Trim: Pontiac Bonneville 2003 SE 3800
My right foglamp doesnt work unless i kick it, then it will stay on until i turn it on again.
Whats the problem, and what is the bulb # for if i need to replace it? Also, *how* do i replace a foglamp?
PostPosted: Mon Jul 16, 2012 1:13 am
It's an H3 bulb. I assume your 2003 SSE is actually either an SLE or SSEi. Either way, you gotta lay down under and there are two 10 mm nuts holding each fog light to the bumper. Then you gotta disconnect the harness powering it. Before getting a new bulb, I'd suggest checking if there is merely a loose connection.
PostPosted: Mon Jul 16, 2012 2:03 am
How would i determine if its an SLE or SSEi?
PostPosted: Mon Jul 16, 2012 11:08 am
SLE = non-supercharged = 8th digit of VIN is a K
SSEi = supercharged = 8th digit of VIN is a 1
You do not need to remove the 10mm nuts to just replace the bulb. Simply release the bulb by rotating counter-clockwise and pull out, then disconnect the wiring harness.
PostPosted: Mon Jul 16, 2012 1:32 pm
Year and Trim: 99 SSEi
01 SLE
02 GTP40th
02 SSEi
06 GP GT
nos4blood70 wrote:
It's an H3 bulb.
H3? These are the same lamp/bulb as 92-99, which used 880 bulbs. I upgrade to 893 in the stock fog lamp housing on my personal cars.
DHP Powrtuner & Tech 2
1998 GTP Coupe
1999 SSEi 70k miles
2001 SLE
2002 GTP 40th Anniv Ed Coupe
PostPosted: Mon Jul 16, 2012 2:53 pm
Year and Trim: 2004 GXP
olblueeyesbonne wrote:
nos4blood70 wrote:
It's an H3 bulb.
It's a 880 stock.
Seth
RogueSSEi wrote:
Bet she'll stop on a dime and give you 3 pennies back!
PostPosted: Mon Jul 16, 2012 4:47 pm
Moderator
Moderator
Year and Trim: 09 G8 GT
2004-2005 GXP and 2005 SLE are the ones that run H3. As said, 880 is what the SLE/SSEi run from the factory.
PostPosted: Mon Jul 16, 2012 5:10 pm
Are your fog lights in the center of the bumper or the outer edges? That describes the difference between the fogs on a SE and an SLE/SSEi.
James May wrote:
Hello.
PostPosted: Mon Jul 16, 2012 6:41 pm
I thought se's had 880 fog light bulbs too? Just a different location.
Seth
PostPosted: Mon Jul 16, 2012 6:44 pm
Yeah, that's true to my knowledge Seth. I'm just making it clear to the OP as to what model car he has, just for clarification. :)
James May wrote:
Hello.
PostPosted: Mon Jul 16, 2012 11:10 pm
The fog lamps are right on the outside of the vehicle. Towards the side all the way
PostPosted: Mon Jul 16, 2012 11:15 pm
Then it is a se.
Seth
PostPosted: Tue Jul 17, 2012 12:33 am
sethjamesrimrodt wrote:
Then it is a se.
Yeah, it looks exactly like the one in your pic, just.. silver lol
PostPosted: Tue Jul 17, 2012 12:54 am
01 SLE
02 GTP40th
02 SSEi
06 GP GT
Your car has the V8 too? Just want to be clear whether you may have the ONE and ONLY SE with V8 and GXP bumpers/foglights.
1998 GTP Coupe
1999 SSEi 70k miles
2001 SLE
PostPosted: Tue Jul 17, 2012 1:10 am
V6, 3.8L
PostPosted: Wed Jul 18, 2012 12:44 am
Sorry for the misinformation on the bulb. Either way. You have an SE. I'd recommend changing your Year and Trim to SE. 880's are the ones you need.
PostPosted: Wed Jul 18, 2012 1:51 am
http://shop.advanceautoparts.com/webapp ... m=bulb+880
This the proper bulb? Should i get two as they will be different brightness?
PostPosted: Wed Jul 18, 2012 8:14 am
That is the correct bulb, I recommend changing halogen bulbs in pairs.
Seth
There are no new unread posts for this topic. 2003 pontiac bonneville se fuse box and relay problems! help
tom4221
Wed Sep 29, 2010 11:29 am
There are no new unread posts for this topic. 95 SSE turn signal lamp holder / lamp monitor problem
SSP_SSE
Sat Jul 25, 2009 5:39 pm
SSP_SSE View the latest post
There are no new unread posts for this topic. Help!! Dashlights, headlights flickering constantly.
comatoast
Fri Jan 25, 2013 5:03 pm
steelmanwy View the latest post
There are no new unread posts for this topic. 2003 Bonneville SSEi won't start
theresaschnee
Fri Mar 23, 2012 6:52 pm
There are no new unread posts for this topic. 2003 Bonneville, turn signal issue.
mikeman
Fri Jul 27, 2012 1:16 pm
Archon View the latest post
