It is currently Wed Oct 08, 2025 6:52 am
Post new topic Reply to topic  [ 15 posts ]
 Post subject: cruise control died
PostPosted: Fri Jan 21, 2011 12:01 pm
Year and Trim: 2003 SSEI
The factory cruise control in my 2003 SSEI died suddenly - I had the cruise set, hit the brakes and it wouldn't resume, and it hasn't worked since. The fuse is good.
There's an old post in this forum where someone had the same thing happen on an older model ('96) and solved the problem by replacing the cruise control servo. Sounds like a good place to start.
Can anyone tell me where the servo is located and/or give some other suggestions for solving the problem?
 Post subject: Re: cruise control died
PostPosted: Fri Jan 21, 2011 12:09 pm
Year and Trim: 1999 SSEi
1997 SSEi-Resting-353K
#1 is your module, but the diagnostic list is extensive. a tech II scanner would narrow it down without guessing.
PostPosted: Fri Jan 21, 2011 7:19 pm
Did you make sure you haven't hit the button to off? I did that once and it took me a bit to realize what had happened. Also, it only works at over 25 MPH. Not calling you stupid or anything, just trying to eliminate variables.
PostPosted: Sat Jan 22, 2011 12:37 pm
First make sure your SES (check engine soon) light isn't on. There are other components that can kill your cruise.
PostPosted: Sat Jan 22, 2011 2:55 pm
I just had to replace a $25 brake switch and got the CC working just fine now.
Start with the less expensive components first. The CC module cost big bucks. Do without it if thats fried.
PostPosted: Mon Jan 24, 2011 12:03 am
Year and Trim: Daily Driver: 2011 Impala LT
Weekender: '95 Aurora
I had a '94 Olds LSS (first of two LSS's I owned) that the cruise control died on. First, the button on the end of the turn signal lever quit working, then the on/off/resume switch quit a few months later. Shortly after that, I had to have the ECM replaced because of some unrelated issues and the cruise miraculously began working again.
Weekend Toy: 1995 Olds Aurora
PostPosted: Mon Jan 24, 2011 12:18 am
Something no one mentioned.. There is a little black plastic bracket thing on the throttle cable that is used to physically hold the cable when cruise control engages. Mine broke (seemed to get brittle from the heat).
PostPosted: Tue Jan 25, 2011 2:53 pm
Thanks for the diagram and tips! At least I can now locate the cruise module. Mechanically, everything looks properly connected and unbroken. Also, the way the cruise suddenly failed (on a smooth, straight road at 60mph) leads me to believe the problem is electronic, like a bad switch.
The check engine light hasn’t come on. Might it have some cruise-associated error code anyway? If so, would it tell me if a particular switch was bad?
I’m sure I could tear into the wiring from the switch on the turn signal and use a multimeter to check it, but there might be an easier way. Is it possible to get to switch terminals in the module? Would it be pointless to try testing switches, since the cruise only works at 25+mph?
PostPosted: Tue Jan 25, 2011 3:54 pm
Important
Perform the following in order to avoid misdiagnosis.
Inspect for proper operation of brake lamps.
Inspect throttle linkage for mechanical binding which could cause the system to malfunction.
Inspect cruise control cable adjustment, should have minimum slack.
Inspect for stored diagnostic trouble codes (DTCs) in the PCM. Refer to Diagnostic System Check - Engine Controls in Engine Controls.
When testing vehicles equipped with steering wheel controls, the steering wheel must be rotated to each stop position while testing the cruise control switch signal circuits. This will assure the integrity of the (SIR) coil.
Conditions for Enabling Cruise Control
When vehicle speed is more than 40 km/h (25 mph).
When PARK, REVERSE, NEUTRAL, or 1st gear is not indicated.
When an over/undercharged battery condition does not exist.
With normal engine rpm.
Turn the ignition OFF.
Disconnect the cruise control module.
Turn the ignition ON, with the engine OFF.
Test the ignition positive voltage circuit of the cruise control module with a test lamp that is connected to a good ground.
Does the test lamp illuminate?
Go to Step 3
Go to Step 36
Test the ignition positive voltage circuit of the cruise control module with a test lamp that is connected to the ground circuit of the cruise control module.
Go to Step 4
Go to Step 37
Turn the cruise control switch ON.
Test the on/off, the set/coast, and the resume/accelerate signal circuits with a test lamp that is connected to a good ground.
Does the test lamp illuminate on any of the circuits?
Go to Step 16
Go to Step 5
Test the on/off signal circuit with a test lamp that is connected to a good ground.
PostPosted: Mon Jan 31, 2011 2:45 pm
I think I found the problem.
While going through the pre-test checklist I noticed that the cable at the throttle seemed to have excessive slack. I traced it back to the cruise module, at which point it's a flat fabric type of cable. It looked OK at first, but looking inside the opening I could see that it was only attached by a thread.
That led to another problem though - I can't get the plastic top off of the module. The four screws that hold it on have been removed, but it's not coming off. It doesn't look like there are additional connectors that hold it on, and I've cracked the top trying to get it off!
I'll get it off somehow and find a way to splice the fabric cable back together.
PostPosted: Mon Jan 31, 2011 6:02 pm
I bet harofreak00 could sell you a whole new unit for cheap.
PostPosted: Tue Feb 01, 2011 10:47 am
I got several CC modules here for $20 + shipping.
PostPosted: Tue Feb 08, 2011 3:20 pm
Thanks Beast & Harofreak - a great price on CC modules, but I was able to stitch mine back together, literally. I finally got the top off the module and sewed the broken fabric cable together. It took a little observation to figure out how the reel mechanism inside the module worked in order to adjust it for the proper length, but I got it working again! Thanks to everyone for your help!!!
PostPosted: Sat May 28, 2011 12:02 am
Haro, Would you give me an address so that I can send you a money order for a CC Module?
I live in Topeka, KS if that would help guesstimate the shipping. My e-mail address is rdt46@sbcglobal.net Thanks, Piloti
PostPosted: Sat May 28, 2011 3:22 pm
Email sent
There are no new unread posts for this topic. Cruise Control Fixed
retroren1
Thu Jul 23, 2015 9:02 pm
retroren1 View the latest post
There are no new unread posts for this topic. 2000 ssei Cruise Control
Bmiller269
Thu Feb 27, 2014 11:03 pm
bobgto65 View the latest post
There are no new unread posts for this topic. cruise control doesnt work anymore
MadMike
Thu Sep 01, 2011 9:26 am
There are no new unread posts for this topic. Car died, won't start
tallbump
15
1569
Thu Sep 25, 2014 10:34 pm
There are no new unread posts for this topic. Started and Died No Power!
Gonkystyle
Sat Mar 12, 2011 1:55 am
