It is currently Wed Oct 08, 2025 6:48 am
Post new topic Reply to topic  [ 28 posts ]  Go to page 1, 2  Next
PostPosted: Tue Dec 08, 2009 9:50 pm
My grandson Alex stepped on the traction control switch in his Mom's 2000 SSEi. Now there is no traction control and apparently no ABS (?)
So, my son is trying to repair it or work around it. I looked in my 1995 FSM - the newest I have - section 8a-44-6 - and told him the pinouts to try to jump the switch. But '95 is a long way from 2000, and I am wondering if maybe someone could post or mention what color wires and what terminal designations do what in the 2000 model year.
In '95, a gray wire feeds the illumination for the switch through terminal E and grounds to a black wire at terminal F. A brown/wht wire from the ebtcm feeds the switch through terminal B and grounds to a blk/wht wire through terminal C.
I suggested he try grounding the brown/white wire to see if that would switch the system back on, but thought I might better check with someone who knew better or at least had a 2000 FSM.
Can anyone help?
1998 3.8 Dodge Caravan 214K
2000 3.3 Dodge Caravan 175K
PostPosted: Tue Dec 08, 2009 9:52 pm
I just got to class, but if noone else has responded, I'll look it up when I get home.
PostPosted: Tue Dec 08, 2009 10:18 pm
I'll see if I can find it in my 2000 FSM's quick.
Ok, Looks like the TC Switch switches the Lt. Blue and black wires. Give that a try.
PostPosted: Tue Dec 08, 2009 10:24 pm
A disconnected TC switch should not disable the ABS system.
PostPosted: Tue Dec 08, 2009 11:12 pm
Year and Trim: 2003 SLE || 51k miles
I currently have no TCS or ABS due to a ABS pump failure which in turn burnt out the EBCM. GM wants $2k to repair it......
-Mike
PostPosted: Wed Dec 09, 2009 9:26 am
Thanks, gentlemen, for the replies. I will pass on the information. At least my son has a garage to work in.
PostPosted: Wed Dec 09, 2009 10:21 am
I could just send him a switch for cheap. Probably be there Fri-Sat.
PostPosted: Wed Dec 09, 2009 2:45 pm
Thanks, Haro, PM sent.
PostPosted: Wed Dec 09, 2009 3:48 pm
Don't bad wheel speed sensors knock out TC and ABS?
-Mike
Yes
PostPosted: Wed Dec 09, 2009 3:53 pm
I was talking with my son about this issue and he tells me that he has changed both front wheel speed sensors in the past year, (but none in the rear). He also mentioned that since they have owned the car (a few years, now) whenever the traction control switch was thrown, the ABS light would come on.
PostPosted: Wed Dec 09, 2009 3:59 pm
Sounds like he is having the common "Service Stability System" problem. Even though he changed the front hubs, they could still be a problem, or the rears could be bad, or the steering wheel position sensor, or the EBCM, or the wiring, etc... The only way to check for sure is a trip to the dealer.
The switch I'm sending you will at least fix the broken switch, but I doubt its going to do anything with fixing the system.
PostPosted: Wed Dec 09, 2009 6:28 pm
Makes me appreciate older, simpler cars.
PostPosted: Thu Dec 10, 2009 1:48 am
Prior to the switch being stepped on, when the traction control was shut off via the switch, the "trac off" to the right of the gas gauge, as well as the "ABS off", to the left of the temperature gauge, both lit up...or just one of them?
PostPosted: Thu Dec 10, 2009 1:46 pm
When the switch was thrown, the amber trac off light came on to the right of the gas gauge and the amber antilock light by the lower left corner of the speedo (?) both came on.
Last edited by bill buttermore on Thu Dec 10, 2009 1:50 pm, edited 1 time in total.
PostPosted: Thu Dec 10, 2009 4:37 pm
Interesting. Do we know if the abs is really deactivated when the traction control button is pushed. It appears as if the lights are controlled by the instrument panel module from a signal from the EBCM. Of course, most diagnosis is done with a scan tool. However, listed places to check are: The ground for the EBCM, the connector to the EBCM, as well as any problem along the harness from the EBCM to the IPM. The 2 problem devices listed are the same, EBCM and IPM. Depending on the RPO, instead of the IPM, the AC control module gets involved.
PostPosted: Thu Dec 10, 2009 5:05 pm
Thanks for the input, Dick. I asked son Andrew to follow this thread for clues to the fix. Hopefully, he will chime in eventually.
PostPosted: Fri Dec 11, 2009 11:37 pm
Andrew installed the switch from Haro today (Thanks Haro!), but the trac off and antilock lights stay lit when the switch is depressed, so it would seem that something else (besides the switch) is faulty. We will probably not work on this for a couple of weeks until Andrew's schedule lightens up. I'll try to keep y'all informed. Thanks again for all the help so far.
PostPosted: Tue Mar 23, 2010 12:00 am
Year and Trim: 2000 SSEI
Finally got the car scanned today...
The Left Front Wheel sensor can not be reset.
The tech that scanned the car thinks it is a broken wire as
we have recently replaced the hubs and suggested starting
there. If the wire is good we may need to replace the hub.
I did not have a lot of time tonight, but was able to pull the
wire out of the harness - there is evidence of a splice from
the yellow and blue wires near the transmission to the
white and black wires to the WSS - There is heat shrink
Is that standard or has someone been here before?
PostPosted: Tue Mar 23, 2010 10:35 am
What brand hubs did you use as replacements?
There is a standard heat shrink tubing that runs about a foot or more up the wires to protect it from road debris. Is it different than that? Check the other side and compare.
There are no new unread posts for this topic. pinouts/wiring for ign and headlight switch 96 ssei
~baker~
Sat Apr 07, 2018 5:24 pm
~baker~ View the latest post
There are no new unread posts for this topic. 02 SSEI - how to control headlights with switch only?
corsair
Thu Feb 01, 2018 10:54 pm
corsair View the latest post
There are no new unread posts for this topic. Traction Control Off all other Traction Lights on HELP
CJs03SSEi
Sun Feb 12, 2023 1:57 pm
There are no new unread posts for this topic. 2000 ssei Cruise Control
Bmiller269
Thu Feb 27, 2014 11:03 pm
bobgto65 View the latest post
There are no new unread posts for this topic. Traction Control Button
93BonnevilleV6
Fri Mar 20, 2009 8:29 am
willwren View the latest post
