It is currently Fri Sep 12, 2025 4:13 pm
PostPosted: Thu Dec 08, 2011 6:57 pm
Year and Trim: 1997 SE
When I got to work this morning I was unable to turn off my car. All the shifting, jiggling and turning didn't work. It is going into park and I can hear a click in the steering column, but it won't release the key. I had to remove the battery cables to kill motor. When I got off work replaced cables and cranked the car and drove home. Key is still in ignition. Google has been no help. Does the 97 Bonny have a manual release like the grand prix?
97 SE
It's easier to curse the dark than to look for a match to light that stupid candle.
PostPosted: Thu Dec 08, 2011 7:30 pm
Year and Trim: 97 SE
On ours it was the rubber cover on the gear shift release button was bunched up or whatever. It was stopping it from fully releasing.
I just took ours off. Although our motor would shut off I couldn't get the key out.
2002 Bonneville SLE
PostPosted: Thu Dec 08, 2011 7:47 pm
Year and Trim: 98 SE-95 Lesabre-89 SE 65 Falcon HT
maybe this will help - found on Youtube
http://www.youtube.com/watch?v=BYBD4_Bm_8g
1998 Bonneville SLE 32 mpg
1965 Falcon Futura HT 325hp
1989 Bonnevile SSE
1995 LeSabre LTD
1998 GMC Sierra 4x4
others
PostPosted: Thu Dec 08, 2011 8:12 pm
possible fix 3 part
http://www.youtube.com/watch?v=D-2H20iO ... re=related
http://www.youtube.com/watch?v=oaxhWlgK ... re=related
http://www.youtube.com/watch?v=o8D-5TyD ... re=related
1989 Bonnevile SSE
1995 LeSabre LTD
1998 GMC Sierra 4x4
others
PostPosted: Thu Dec 08, 2011 9:19 pm
It's not the shifter button, I removed the knob and still no luck.
The grand prix is different than the Bonny no release switch under steering wheel.
When I release the shifter button I can hear a click in steering column.
97 SE
PostPosted: Fri Dec 09, 2011 3:13 pm
Try it in Neutral, not park.
PostPosted: Sun Dec 11, 2011 1:02 pm
I have tried it in neutral. No luck.
97 SE
PostPosted: Sun Dec 18, 2011 9:44 pm
UPDATE:
Got it fixed.
It was the lock switch in steering column. While staying with my in-laws in Mexico took it to local mechanic. It cost me $250 pesos with an exchange rate of 13:1 it was less than $20. They pulled steering wheel and replaced part. The part was bent and about to break. Everything's working correctly now. Didn't have to replace keys.
97 SE
PostPosted: Mon Dec 19, 2011 3:16 am
Year and Trim: 1996 pontiac bonneville se
should get your car repaired more in mexico at those rates lol
http://i1190.photobucket.com/albums/z447/razmatazz1/Untitled-1.jpg
This topic is locked, you cannot edit posts or make further replies. "Clunk" noise when I turn left to right
labonnevillastrangiato
14
6092
Wed Mar 02, 2011 5:32 pm
repinS View the latest post
There are no new unread posts for this topic. "weak" P/S front door actuator; replaced... still "lazy"
SimoreButts
Wed Feb 15, 2012 12:18 pm
There are no new unread posts for this topic. Traction Control "STUCK' on
olblueeyesbonne
Mon Aug 31, 2009 1:25 pm
There are no new unread posts for this topic. 1998 SSEI History of "Electrical System Checked" Concern?
sgmburke
Tue Sep 02, 2014 9:50 pm
1998BonneSSEI View the latest post
There are no new unread posts for this topic. How do I trouble shoot "MAP...Pressure Circuit High Input"
douglas
Sat Dec 04, 2010 8:42 pm
