It is currently Sat Oct 11, 2025 4:44 pm
Post new topic Reply to topic  [ 15 posts ]
PostPosted: Tue Apr 23, 2013 12:35 pm
Year and Trim: 2003 Bonneville SE -normally aspirated- 4 door
http://intense-racing.com/Merchant2/mer ... _Induction
I got mine from Intense yesterday and it looks good, but the directions are for a Grand Prix. Like you, I have a Bonneville....
Are there any installation differences I should know about before I begin, or just follow the directions to the letter?
D.T.
PostPosted: Tue Apr 23, 2013 2:12 pm
Year and Trim: 2002 Pontiac Bonneville SE
drift7one wrote:
http://www.bonnevillepro.com/forums/viewtopic.php?f=175&t=5644
drift7one
Rich- Member #6668
Golden Hurricane
| Cleared Headlights | 20% Tinted Windows | AVS VentVisors | Viper 2-Way Alarm System | Garmin GPS Navigation |
| DDM Tuning 8000k 35w HID Headlights | Nokya Hyper Yellow 2500K Fog Lights | Black PlastiDip Accents & Badges |
PostPosted: Tue Apr 23, 2013 2:46 pm
post143936.html
PostPosted: Tue Apr 23, 2013 6:14 pm
The link above is how I did it, but I also removed my headlight.
PostPosted: Tue Apr 23, 2013 8:58 pm
I will use the "remove headlight" route instead of removing the tire. Sounds a lot easier.
D.T.
PostPosted: Wed Apr 24, 2013 9:55 am
I removed my tire. My only regret is that I wish I could have gotten the filter to sit more horizontal than vertical, but I'm not even sure if this is possible.
Matthew
1998 Chevy K1500 Silverado Z71 ECSB L31 -- project/toy
1998 Chevy S10 ZR2 ECSB L35 5spd -- winter truck
2002 Pontiac Bonneville SSEi -- stock (trying to keep it that way...we'll see...)
PostPosted: Wed Apr 24, 2013 12:38 pm
You want it vertical, that way any water splashed onto it is able to easily fall off, instead of sitting in the pleats of the filter.
This all reminds me, my K&N is probably disgusting...
PostPosted: Wed Apr 24, 2013 12:42 pm
01 Bonneville SSEi
09 G8 GT
Same here Ed, as I don't think I've cleaned it since I got it, 4 years and 48,000 miles ago. . .
PostPosted: Wed Apr 24, 2013 1:22 pm
I never thought about it that way. I was thinking you wouldn't want it sticking down into water if that were to happen.
I would like to get mine so that it isn't pushing down into the lower plastic valance so much though. Probably try to get more of a 60* angle.
Matthew
PostPosted: Wed Apr 24, 2013 1:41 pm
Year and Trim: '02 SSEi
Mine was a tight fit and the filter actually got squeezed a little bit. I think before I put my bumper cover back on I might buy a slightly smaller filter.
PostPosted: Wed Apr 24, 2013 4:19 pm
Is that a possibility? Has anyone ever tried/used a different filter than what was supplied in the kit?
Matthew
PostPosted: Wed Apr 24, 2013 4:45 pm
01 Bonneville SSEi
09 G8 GT
I'm thinking about using the filter that's in my LeSabre, because it's an X-Stream filter (has some filtration on the end cap), but I think that's an even bigger filter.
PostPosted: Wed Apr 24, 2013 9:24 pm
Year and Trim: 2000 SSEI
Using K&N RU-3130 3.5" inlet and smaller in size.. no problems. you can try using a Pre-filter over the K&N to help keep it clean..
like so:
Shane "RedZMonte"
2004 Z16 Z06: Virgin
PostPosted: Wed Apr 24, 2013 11:39 pm
I had to jam the cone under there and it's kinda crumpled against the bumper, but it does the job. I've gotten into much too deep water many times with it, nothing really happened. I don't know if the engine produces enough suction to suck up water at lower RPM levels. (1500 or less.) That's just my hypothesis.
PostPosted: Thu Apr 25, 2013 12:09 am
redzmonte:
I like your pic/ idea of the smaller filter. We use to run those pre-filters in go-kart racing on dirt tracks and they really did help catch a ton of dirt and crud. Another item we used was a pre-filter made of foam like you'd see on a Briggs & Stratton mower engine. It has this green foam pre-filter that goes over the actual air filter. Coat that foam pre-filter and it catches an immense amount of foreign matter. Sure easy to clean because you just peel it off, wash in warm soapy water, oil again, and stretch back over your Cone filter like a sock over a foot. You never have to take the Cone filter out....I see the same process for your pre-filter wrap in the picture.
D.T.
There are no new unread posts for this topic. Shift Kit installation
xyeLz
Mon Mar 10, 2014 11:44 am
xyeLz View the latest post
There are no new unread posts for this topic. headers installation
samples08
Sat Jul 16, 2016 9:00 pm
Erinyes View the latest post
There are no new unread posts for this topic. 4T65 TransGo shift kit installation
LeSabre in Buffalo
30
16552
Mon Aug 12, 2013 6:39 pm
xcbullet View the latest post
There are no new unread posts for this topic. 2003 180 degree thermostat installation
2003blackbonniese
Mon May 04, 2009 9:23 pm
There are no new unread posts for this topic. Intense PCM or ZZP PCM?
Black Pearl
14
4945
Sat Sep 19, 2009 11:48 am
olblueeyesbonne View the latest post
