It is currently Fri Sep 12, 2025 4:11 pm
PostPosted: Fri Nov 10, 2023 6:01 pm
Year and Trim: 2000 pontiac bonnevile SSEI
car full without breaking get the lens off , it’s hard but patience , then buy some JB clear weld , scuff the black plastic with a sandpaper to allow it to bond better , then lather up the plastic and lens , more on the black plastic , then clamp , and i mean clamp tons of them to get rid of the air bubbles , do not clamp too hard tho or it. will crack
PostPosted: Fri Nov 10, 2023 9:08 pm
got pics? I've tried what you're talking about and it looks horrible, especially on the horizontal black lines
PostPosted: Mon Nov 13, 2023 1:00 pm
Also interested in seeing some pics.
PostPosted: Tue Nov 21, 2023 10:15 pm
Year and Trim: 1993 SSEi
My car had been sitting outside for a long time and both taillight lenses eventually got rainwater in them (a lot of rainwater -- one turn-signal bulb was actually half-full of water itself). I didn't want to do more damage by trying to pry the lenses apart because I could see they were not going to let go without a fight. I finally resolved the problem by leaving each light assembly intact and just drilling a weep hole at the lowest point of the bottom of the housing to let out any internal moisture. It didn't need to be a very big hole; I think mine are 3/16" or so.
(I did give them a thorough drying out while they were off the car to have the weep holes drilled. I rinsed them out with clean water through the socket holes, and set them face-up over a floor air vent in our house to run warm air through them for a few hours. All good now.)
There are no new unread posts for this topic. rear reflector
blackbeauty00
Wed Mar 02, 2011 6:39 pm
99BonnevilleSE View the latest post
There are no new unread posts for this topic. Rear window & reflector Mod?
SAMzGXP
16
3191
Wed Sep 30, 2009 12:08 pm
SAMzGXP View the latest post
There are no new unread posts for this topic. Bonneville Center Reflector Disassembly/Restoration
20SSEi00
Wed Feb 19, 2025 2:46 am
20SSEi00 View the latest post
There are no new unread posts for this topic. smoked taillights
philly
Wed Feb 22, 2012 8:51 am
There are no new unread posts for this topic. How do ya clear colors from the taillights on a 2002 SSEi ?
Bluzak247
Mon Apr 13, 2015 6:01 pm
