It is currently Sat Oct 11, 2025 4:55 pm
 Post subject: Mass air flow
PostPosted: Wed Jun 29, 2016 5:50 pm
Year and Trim: 2002 ssei
My car is stalling out at random times. Sometimes it will be days or hours in between. I've had codes run on the vehicle and I'm pulling up mass or flow sensor. I've read on a few other sites that unplugging the sensor will default the system for a temporary fix. I'm about an hr away from home so well I guess I'm asking if I unplug my maf will the engine be better off since running with it plugged in could cause me to run lean and damage the engine? I do plan on getting it replaced but I also need to get home lol so I'm just trying to see what my options are and what to do. I thought it may have been my fuel pump causing the problem so I just ran it like this, this past week. If you're wondering why I've just now checked the codes. 2002 pontiac bonneville ssei
 Post subject: Re: Mass air flow
PostPosted: Wed Jun 29, 2016 6:46 pm
hi, wont make much difference if your driving only 60 - 100 miles - I would just take it easy and dont go past 25 % throttle
PostPosted: Wed Jun 29, 2016 7:25 pm
If it's still running, I would rather deal with stalling for the trip home, assuming it restarts without much drama, and only use this method as a last resort.
Also, while doing it, DO NOT build boost.
PostPosted: Thu Jun 30, 2016 12:53 am
Just wanted to update you guys and tell you thanks for giving me the confidence to drive her home. We are both home safe and sound and she will be getting a new maf sensor tomorrow :banana:
PostPosted: Thu Jun 30, 2016 9:13 am
Year and Trim: 1993 SLE
1998 SE
2001 SSEI
2002 SSEI
Just make sure that you either buy a premium brand like ACDelco or Delphi or get a good used OE MAF from a junkyard.
Be aware that ACDelco has a few product lines---according to the quality of the part. The best is Original Equipment; Middle grade is Professional ; Worst is Advantage.
If going used, then buy some MAF sensor cleaner spray to clean the sensor elements before installing it.
Other cleaners leave residue that prevents the sensor from working right or actually damages the sensor.
Many here have found other brand MAFs seem to have a high failure rate.
PostPosted: Thu Jun 30, 2016 12:07 pm
Agree with the above, always try and find an OEM sensor that is known to be good.
PostPosted: Sat Jul 02, 2016 4:06 pm
So I was unable to find a used known to be good maf sensor. Called around and wow, a brand new acdelco is 418$. So I am going to settle for a delphi brand that needs to be special ordered from AutoZone for 145$. Is this going to serve my car good? My other options are sparxs brand I think they said and some other brand for 118$
PostPosted: Mon Jul 04, 2016 11:24 am
1998 SE
2001 SSEI
2002 SSEI
...or you could spend $90 for the same exact part at Rockauto lookup DELPHI AF10126
Use the discount code from the vendor's forum to get an additional 5% off
PostPosted: Mon Jul 04, 2016 11:32 am
...Or hit up Harofreak00
PostPosted: Sun Jul 10, 2016 11:20 pm
Will any 3.8 maf sensor work or do I need to have one that came off a supercharged 3.8? The reason asking is because ive found a treasure trove of 3.8 maf sensors but they are on impalas, regals and grand prix, etc...
PostPosted: Mon Jul 11, 2016 12:00 am
I'm not sure if the L67 and L36 have different sensors or not, but d look for ACDelco, Delphi, Hitachi, or maybe even Dorman brand.
PostPosted: Mon Jul 11, 2016 12:43 am
Year and Trim: '99 Montana
'92 Trofeo
There is a part number on the middle of the sensor, if you find one that matches on any other 3800 car then it's the same sensor.
There are no new unread posts for this topic. Air Flow Straighteners
jradke61
20
3585
Sun Feb 12, 2017 12:07 pm
jradke61 View the latest post
There are no new unread posts for this topic. High Flow Cat Suggestions?
Blown93SSEi
Fri Dec 18, 2009 2:14 pm
There are no new unread posts for this topic. 3800 water flow diagram?
MattStrike
Mon Jul 28, 2014 10:45 pm
There are no new unread posts for this topic. Flow Master Muffler Question For 97 Bonne. Model 9/24/2010
97SEBonnevilleMan
Thu Dec 23, 2010 2:17 pm
rrounds View the latest post
