It is currently Fri Sep 12, 2025 4:17 pm
PostPosted: Mon Aug 21, 2017 1:49 pm
Year and Trim: 2000 SLE 155k
https://youtu.be/GACW--2PNAA
this is the exact same sound my car is now making, haven't been driving it lately due to the rear strut [fully collapsing i think] worse than what it was,, i wanted to move it into the street.
-Come to think of it the car didnt sound like the video when i first started it and sat for a bit
SO while going down my drive way i hear awful metal scraping cement sound that i know to well, was muffler scraping the street where it inclines to my driveway as i went down.. SO went backup put in park and started making that noise shortly after
smoke appears to be coming from back of engine, i know i have a oil and coolant leak.
this seems a good link for possible causes and how to fix?
https://www.2carpros.com/articles/vehic ... ping-noise
-the smoke is light grey, and smells like burning rubber oddly.
The video in the link lead to a bearing on the serpentine belt being the cause ?
-AC was off and i never used it as it doesnt work
PostPosted: Mon Aug 21, 2017 5:00 pm
hi, the smoke could be oil burning when it touches hot exhaust pipes.to identify the a/c bearing, remove the serpintine belt and let idle for 5 minutes from cold start - if the sound goes away, its the a/c pulley, bearing. check it for play by hand when you remove the belt.
you wont have power steering or water pump flow with belt off so dont drive until you reinstall.
PostPosted: Mon Aug 21, 2017 5:16 pm
would running car w ac on/off do anything?or watch for ac clutch to engage?
PostPosted: Thu Aug 24, 2017 12:09 pm
Year and Trim: 1993 SLE
1998 SE
2001 SSEI
2002 SSEI
The AC clutch can scrape against the pulley with the AC off.
Best to fix the oil and coolant leaks. Oil dripping onto hot exhaust can become a fire.
Coolant leaks can lead to overheating.
It's relatively easy to replace the rear shocks.
Info on replacements
post467364.html?hilit=rear shocks#p467364
PostPosted: Thu Aug 24, 2017 7:38 pm
When the car is idling, pull the oil cap off and see what happens, if it changes behavior or if the car runs differently.
PostPosted: Sat Aug 26, 2017 1:15 pm
i dunno if you saw the pick i showed, but the whole wheel house is rusted out where the strut goes into, i had a pic here somewhere, but i think its beyond repair nor will a wielder do it due to rust
btw i got a new SUV 2005 toyota highlander limited, people seem to recommend Toyota a lot?
I'm parting this car out if anyone reading would be interested in the engine ,parts, ICM,or 3 new 17" tires
There are no new unread posts for this topic. Front wheel grinding sound + brake light
GerGa
12
1738
Wed Dec 14, 2016 2:46 pm
jradke61 View the latest post
This topic is locked, you cannot edit posts or make further replies. Smoke from under the engine
00ssei
14
2988
Fri Aug 15, 2008 11:39 am
BlackHawk99 View the latest post
There are no new unread posts for this topic. smoke coming from engine
20Bonneville00
Fri Oct 04, 2013 7:59 pm
20Bonneville00
Fri Oct 04, 2013 7:57 pm
There are no new unread posts for this topic. Baffled by white engine smoke, loud noise, and now no crank
Fogeddabotit
Sun May 15, 2016 1:41 am
96 SSEi View the latest post
Users browsing this forum: No registered users and 19 guests
