It is currently Sat Oct 11, 2025 11:36 pm
PostPosted: Thu Aug 10, 2017 12:47 pm
Year and Trim: Looking at a 2000 SSEI with 124,000
This is my wife's DD.
She was driving it Sunday and no problem.
Tried to start it up on Monday and it won't run.
Engine cranks but will not start unless I press the accelerator.
When I lift my foot of the accelerator it stumbles and stops running.
There is no service engine light and the car has not set any codes.
The plugs and wires are new within the last 12 months, new ICM within the last 3 months. Just changed out the ICM today (it was under warranty) because I felt the symptoms were similar to the problem I had earlier this year that required I replace the ICM.
A/C Delco fuel pump replaced within the last 12 months.
Supercharger rebuilt within the last 3 years.
At a loss of where to check next.
Need some help to get this car back on the road again.
Thanks in advance.
- Bret
PostPosted: Thu Aug 10, 2017 1:14 pm
Unplug the MAF sensor.
PostPosted: Thu Aug 10, 2017 2:04 pm
x2 on unplug the Maf - and if it indeed solves the issue, you can try cleaning the maf wires.
PostPosted: Thu Aug 10, 2017 5:37 pm
Unplugged the MAF and no effect.
Any other ideas?
I noticed that the boost on the supercharger wasn't very high at 2000 rpm.
Removed the supercharger belt and no change.
Unless I keep my foot on the accelerator and keep the rpm >750 the engine dies.
I have new vacuum hose to the T under the snout of the supercharger.
Could the fuel pump have failed? It is a new within the last 6-9 months AC Delco.
Thanks for your help so far.
PostPosted: Thu Aug 10, 2017 5:53 pm
How can you test the IAC?
From other posts I've seen in the past few minutes, the symptoms my car is having are similar to another guy who had a bad IAC.
Any way to test that?
PostPosted: Thu Aug 10, 2017 8:49 pm
Year and Trim: 2002 sle
Try cleaning throttle plate and bore.
PostPosted: Fri Aug 11, 2017 9:00 am
I'm gonna say vacuum leak now. Since you were messing with the lines when you did the new T under the snout, maybe you bumped and cracked a fitting?
PostPosted: Fri Aug 11, 2017 3:10 pm
It was the IAC.
When I removed it, the plunger was extended all the way. :banana: :bwoohoo:
Put the new one in and the car ran like it should.
Thanks for your help everybody!
- Bret
There are no new unread posts for this topic. 2003 SSEi rough idle but fine under throttle
rynmcdonald
16
2966
Fri Apr 07, 2017 1:32 pm
sseilmnop View the latest post
There are no new unread posts for this topic. 02 sle wont start cold unless hold foot on gas. need help.
kdrm1984
18
3838
Mon Jan 09, 2017 11:17 am
96 SSEi View the latest post
There are no new unread posts for this topic. Odd Crank but No-Start, Cruddy Idle - 2001 SSEi
GP1138
Fri Jan 15, 2021 3:13 pm
GP1138 View the latest post
There are no new unread posts for this topic. Dies after start; driven with foot on accelerator to prevent
imidazol97
Fri Jul 11, 2008 12:48 pm
HurstGN View the latest post
There are no new unread posts for this topic. 2000 SSEi won't idle when cold
rmorton
19
3263
Thu Jan 17, 2013 11:39 am
Users browsing this forum: No registered users and 21 guests
