It is currently Sat Oct 11, 2025 8:40 pm
PostPosted: Mon Mar 23, 2015 3:23 pm
Year and Trim: 2001 SSEi
So...
My 2001 SSEi currently has the jacked up rear end thing going on.
From what I have gathered, since it will not go down, the problem is likely the leveling sensor has finally gone bad.
Before I replace it, are there any ways to get it to drop the rear again? I have let the air out of the compressor, hoping that it would correctly adjust when restarted, but no luck.
I did check the fuse for the air release and it was ok.
It would appear the tie rod piece between the two ball joints may be threaded. If so, can this be turned farther apart, so that the system (may) react by lowering the ride height, or do I just go ahead and get a replacement?
Please advise if I have the correct part number also, thanks:
25728489
Happy trails,
Keith
(Subtle variations in spelling and grammar do not reflect on the quality of this message, nor should they detract from your appreciation of a given message, as they are a sign of its handmade quality and contribute to its overall uniqueness.)
PostPosted: Tue Mar 24, 2015 10:38 pm
Bump.
Anyone?
PostPosted: Tue Mar 24, 2015 11:52 pm
That is the proper GM part number for the sensor. I'd suggest contacting Andrew (Harofreak00) for a good used one, as a new one from GM runs close to $275.
To get the ride height down in the meantime, try pulling the ELC relay in the rear fuse box.
PostPosted: Wed Mar 25, 2015 9:14 am
Ah, had not thought about the relay.
Thanks. Will try that and get a replacement.
Happy trails.
There are no new unread posts for this topic. Ride height sensor...
jla1989
Mon Jul 30, 2012 5:40 am
There are no new unread posts for this topic. Ride Height Sensor
Wayne Adam
Sat Apr 03, 2021 11:53 pm
Wayne Adam View the latest post
There are no new unread posts for this topic. Rear Load Leveling Air system
2000Silverbullet
Thu Dec 18, 2008 7:37 pm
There are no new unread posts for this topic. Air Compressor (tire and load leveling)
seekinhighhp
Wed Dec 01, 2010 4:36 am
locowbl
12
4747
Wed Aug 10, 2011 3:09 pm
locowbl View the latest post
Users browsing this forum: Google [Bot] and 26 guests
