It is currently Thu Oct 02, 2025 2:37 pm
PostPosted: Tue Oct 11, 2011 10:37 am
Year and Trim: 2003 Silver SSEI
Iv done some research and iv pulled half my pass side dash apart, can somebody tell/ show me where to find the vacuum lines that control this, I'm assuming this is the problem. Any info greatly appreciated! Thanks
PostPosted: Tue Oct 11, 2011 10:47 am
Year and Trim: None
Someone else posted about their car being stuck on one setting and he found a bad fuse under the rear seat. Maybe you will be as lucky?
2004 Saturn Ion 3 Quad Coupe
PostPosted: Tue Oct 11, 2011 10:58 am
Really? How do I get to said fuse lol iv only had the car about 3 months so excuse the newb questions lol
PostPosted: Tue Oct 11, 2011 11:02 am
Year and Trim: '03 SE, Galaxy Silver
Pull up on the front edge of the back seat, it pops out...
Go down to the third post for vacuum controller location and diagram.
http://www.pontiacbonnevilleclub.com/fo ... les#p27612
Kurt
'03 Bonneville SE
'07 Yukon XL
'00 K2500 Crew
PostPosted: Tue Oct 11, 2011 11:31 am
Thanks for the link, I think iv seen that post but isn't that for an older model, I have a 03 is there a difference?
PostPosted: Tue Oct 11, 2011 11:50 am
Oops, you are right. There is no vacuum controller (thus my confusion), there are electric actuators that move the valves. They are on the sides of the case - the mode valve actuator is on the drivers side. I've never done it so maybe someone else can give you some insight. Here is an exploded view - #33 is the mode actuator.
http://www.genmotorinfo.com/Picture.asp ... SM%2c+(CJ2)+-+MH09027
Kurt
'03 Bonneville SE
'07 Yukon XL
'00 K2500 Crew
PostPosted: Tue Oct 11, 2011 11:57 am
Thank you sir!!! Hopefully someone whose done it before chimes in
PostPosted: Tue Oct 11, 2011 5:38 pm
U think it needs to be replaced?
PostPosted: Tue Oct 11, 2011 5:42 pm
Check those fuses, it was #33 IIRC on the other car that had this problem last week.
There are no new unread posts for this topic. How to get to HVAC mode actuator to replace?
Jazzy
Wed Apr 21, 2021 10:48 am
Erinyes View the latest post
There are no new unread posts for this topic. HVAC malfunction after battery change
rachellegnion
Mon May 27, 2019 11:34 pm
96 SSEi View the latest post
There are no new unread posts for this topic. 3 problems; no start, defrost only and now cold only defrost
sseilmnop
11
2166
Mon Jan 09, 2017 7:43 pm
sseilmnop View the latest post
There are no new unread posts for this topic. No Defrost or Floor vent
DieselMan
Tue Jan 07, 2014 2:25 pm
DieselMan View the latest post
There are no new unread posts for this topic. A/C blows only at defrost and floor
ParkAve666
Sat May 12, 2018 3:43 pm
Users browsing this forum: No registered users and 27 guests
