It is currently Fri Sep 12, 2025 4:16 pm
PostPosted: Mon May 30, 2011 12:41 pm
Year and Trim: 2000 SE 118k miles
Was doing some additional research on this transmission and came across a few other things. My transmission shifts fine for first 15 minutes of operation, then hard shifts when it gets hot or after highway driving. Replaced the PCS and the 2 other transmission sensors, new filter and fluid, transmission gasket. The transmission didn't have any shavings when pan was pulled. Problem stopped for about a week then came back with a vengence. Just seems like this car has an evil electronic overlord abusing the poor transmission. Can't really tell if the internal seals of the tranny are just shot, so the pressure drops and causes hard shift overlording by the computers, or whether the transmission is actually ok but the electronic monitoring system is all out of whack and overreacts. I read about the following through some microsoft site:
Known problems:
1. "Problem with the connections of the Transmission pass througb connector." Never heard of this. Could a greased up connector cause shifting problems?
2. "Failure of the programming of Powertrain Control Module (PCM). Fix: Reprogram PCM. $65."
Would either of these things, if working incorrectly, also cause hard shift problems?
PostPosted: Mon May 30, 2011 11:13 pm
The connector can. There should be codes set, although many code readers may not see them. This is the TSB regarding that.
Quote:
Bulletin No.: 02-07-30-022B
Date: October 20, 2003
TECHNICAL
Subject:
Service Engine Soon (SES) Light On With DTCs P0716 and/or P0717, P0730, P0753, P0758, P1860, P1887, or other Miscellaneous Transmission Trouble Codes Set (Repair Wiring at Transaxle Wiring Pass-thru Connector)
Models:
2000-2004 Buick Century, LeSabre, Park Avenue, Regal
2003-2004 Buick Rendezvous
2000-2001 Chevrolet Lumina
2000-2004 Chevrolet Cavalier, Impala, Malibu, Monte Carlo, Venture
2004 Chevrolet Classic
2000-2002 Oldsmobile Intrigue
2000-2003 Oldsmobile Aurora
2000-2004 Oldsmobile Alero, Silhouette
2000-2004 Pontiac Bonneville, Grand Am, Grand Prix, Montana, Sunfire
2001-2004 Pontiac Aztek
2000 Toyota Cavalier
with 4T65-E, 4T40-E or 4T45-E Transaxle (RPOs MN3, MN7, M15, M76, MN4, MN5)
Supercede:
This bulletin is being revised to add the 2004 model year as well as the Chevrolet Classic model. Please discard Corporate Bulletin Number 02-07-30-022A (Section 07-Transmission/Transaxle).
Condition
Some customers may comment that the Service Engine Soon (SES) indicator is illuminated and that while the light is illuminated, transmission shifts are extremely harsh.
Cause
These types of conditions may be caused by an intermittent connection at the transaxle 20-way connector to the wiring harness interface.
Correction
If a DTC was recorded and the Freeze Frame and Failure Records back it up, a problem existed at one time with the wiring and/or the connectors between the transaxle and the PCM. Therefore, a thorough inspection and/or repair of the wiring harness at the transaxle 20-way connector for one or more of the following conditions may be warranted.
^ The wiring harness is stretched too tightly or other components are pressing on the connector body itself causing a downward pressure on the connector body and possible intermittent contact of the wiring terminals. Ensure proper clearance to any other components and wiring (i.e. hoses, battery cables, etc.).
^ The terminals are not fully seated into the cavity of the connector body.
^ The male terminals in the transaxle portion of the connector may be in the wrong position (i.e. bent).
^ The female terminals may be loose and are not making proper contact. Check the tension with the proper terminal tester from the GM Terminal Test Kit J 35616-A or J 35616-92. If the tension is low, replace the terminal. Do not try to re-form the terminal.
^ The crimp of the terminal to the wire may not be satisfactory (i.e. loose, over insulation, etc.).
^ The wiring connector is not properly seated and locked in position. Ensure proper seating of the connector into the transaxle and that the connector is properly locked in place.
This is another.
Quote:
Bulletin No.: 0O-07-30-002B
Date: July, 2002
TECHNICAL
Subject:
Slips, Harsh Upshift or Garage Shifts, Launch Shudders, Flares, Erratic Shifts and Intermittent Concerns, DTC P1811 or P0748 Set (Replace Pressure Control Solenoid Valve Assembly)
Condition
Some owners of the above vehicles with a HydraMatic 4T65-E transaxle may comment on harsh upshifts or harsh garage shifts, soft shifts, shudders on hard acceleration, or shifts erratic. These conditions may appear intermittently or set a DTC P1811 or P0748. During diagnosis, a low or high line pressure (actual versus desired) may be observed.
Cause
The above condition may be due to any one of the following which may affect line pressure output:
^ Sediment inside the pressure control (PC) solenoid valve, causing the PC solenoid valve to mechanically bind.
^ Sediment in the valve body, causing the torque signal regulator valve to stick.
^ Incorrect transaxle oil level.
PostPosted: Tue May 31, 2011 11:15 pm
So where is this transmission connector at? Funny one time I had a '91 Mustang 5.0 where the cruise control didn't work and all I did was clean the connector down by the transmission and it worked again.
PostPosted: Tue May 31, 2011 11:17 pm
Pretty sure it's the big one straight below the throttle body on the back of the bellhousing. Might want to remove it, hit it with some contact cleaner and make sure it seats tight upon re-installation.
PostPosted: Tue Nov 04, 2014 10:33 pm
torero500, can you tell me if you resolved your transmission problem and what the solution was? I am in the same boat. 2 years ago, I replace the PCS, fluid and filter, but after another 7000 miles, the problem came back.
PostPosted: Wed Nov 05, 2014 9:18 am
Welcome ryalrodo, please do not dig up old threads. Next time start your own in the appropriate section.
We now know that the installation of a shift kit cures the harsh shift problem. Google TranGo shift kit for the 4T65.
There are no new unread posts for this topic. transmission hard shift
mr.haney
Wed Jul 09, 2014 11:50 pm
There are no new unread posts for this topic. Transmission hard shift
Oldman
Thu Dec 01, 2011 9:10 pm
Oldman View the latest post
There are no new unread posts for this topic. Transmission (?) hard shift - turn off - then OK,,,?
polo
Tue May 06, 2025 8:02 pm
craigstyz View the latest post
There are no new unread posts for this topic. Transmission Hard Shift when warmed up
Bonneville since 1984
Sun Dec 09, 2012 9:39 am
Bing View the latest post
There are no new unread posts for this topic. hard shift
override93
Mon Mar 24, 2014 12:50 pm
override93 View the latest post
Users browsing this forum: No registered users and 19 guests
