It is currently Sat Oct 11, 2025 11:39 pm
 Post subject: 2001 SSEi Will Not Start
PostPosted: Thu May 05, 2011 1:27 pm
Year and Trim: 2001 SSEi
I tried to start the car yesterday and received the Service Theft System message on the DIC. The Security (steady on), Service Engine Soon, and Battery lights are also on.
Has anyone encountered this before or does anyone have any suggestions?
Thank you.
PostPosted: Thu May 05, 2011 2:17 pm
Ignore the SES light and the battery light, they come on when you try to start the car.
PostPosted: Thu May 05, 2011 2:24 pm
Thanks for the reply.
These are the only lights that remain on when the key is left on the 'on' position. Shouldn't the SES and battery light go off after the initial start-up cycle?
I'm at a complete loss as to what is going on.
PostPosted: Thu May 05, 2011 2:29 pm
They go off when the engine turns on.
Have you tried disconnecting the battery for a bit? Touch the cables together to help discharge the system, then hook it all back together and try again.
PostPosted: Thu May 05, 2011 11:05 pm
Does the engine crank?
PostPosted: Fri May 06, 2011 6:01 am
No, the engine does not crank. I am going to try to disconnect the battery tomorrow and see if that might be the problem.
PostPosted: Fri May 06, 2011 8:11 am
Do you have another key to try?
PostPosted: Fri May 06, 2011 8:19 am
Yes, I've tried both PK3 keys and both produce the same results. I hope it's the battery and not something with the anti-theft system. I'm fearing a wiring or sensor problem....you know, hope for the best but expect the worst!
Thanks for your reply, btw.
PostPosted: Fri May 06, 2011 8:33 am
What does the DIC say the battery voltage is? How old is the battery?
PostPosted: Fri May 06, 2011 9:00 am
The DIC says the battery voltage is 10.4. I bought the car last November and haven't had the battery out so I really don't know how old the battery is. I have been having the Service Theft System intermittently on the DIC since purchasing the vehicle...seemed to appear especially in the cold weather.
PostPosted: Fri May 06, 2011 9:02 am
The car will not start with 10 volts. Charge the battery, or buy a new one.
PostPosted: Fri May 06, 2011 9:08 am
Thanks again for the replies. I will change the battery this weekend and hopefully that will solve the problem.
There are no new unread posts for this topic. 2001 SSEi, Hard Start
garlandchaos
Fri Jul 11, 2008 8:48 pm
There are no new unread posts for this topic. 2001 bonneville ssei crank, no start
dematka
Mon Jul 16, 2012 5:33 pm
There are no new unread posts for this topic. 2001 SSEi intermittently won't start...difficult to diagnose
howdy
12
2447
Wed Sep 17, 2014 11:01 am
howdy View the latest post
There are no new unread posts for this topic. Odd Crank but No-Start, Cruddy Idle - 2001 SSEi
GP1138
Fri Jan 15, 2021 3:13 pm
GP1138 View the latest post
There are no new unread posts for this topic. 2001 SLE "hot start" condition ???
GK55
Sun Sep 06, 2015 11:45 pm
GK55 View the latest post
Users browsing this forum: No registered users and 20 guests
