It is currently Tue Sep 30, 2025 4:01 pm
 Post subject: CEL with P0135 error?
PostPosted: Tue Jul 29, 2014 6:58 pm
Year and Trim: 1998 SE
Hi all,
Noob bonnie owner. '98 SE with 123K miles. Runs and drives great, shifts smooth, no issues accelerating, no leaks, no smoke, coolant levels rock steady.
CEL light came on this morning driving to work... only have to go 3 miles.
Took it to Advanced Auto since I wanted to grab a PureOne air filter and had them scan the car...
P0135 - which after searching here on the forums sounds like it's the forward O2 sensor?
I'm looking up the part - hope it's not expensive.... Is this easy to replace? Is there anything else that could cause the same error to trip?
I'm hoping this is something quick, cheap, and easy to fix
PostPosted: Wed Jul 30, 2014 9:10 am
Replace it with a Delco one-no off brands. E-bay has them for about $40.
The sensor is in the rear exhaust manifold. Uses a special socket, about $8, see the parts puppies. Should swap out in about 15-20 minutes.
PostPosted: Wed Jul 30, 2014 9:40 am
Thanks for the info!
I'll look on ebay for a Delco one and find this special socket... sounds easy enough :)
PostPosted: Wed Jul 30, 2014 10:05 am
http://www.ebay.com/itm/NEW-AC-DELCO-O2 ... fb&vxp=mtr
PostPosted: Wed Jul 30, 2014 10:13 am
EXCELLENT! :hail:
There are no new unread posts for this topic. P0135
chiliagon
Fri Jul 23, 2010 10:33 pm
There are no new unread posts for this topic. P0135 Code?
94SilverSSEi
18
6450
Thu Apr 28, 2011 4:20 pm
There are no new unread posts for this topic. DTC P0135 pre-cat heated O2
Backhoe
Fri Dec 06, 2013 4:21 pm
Backhoe View the latest post
There are no new unread posts for this topic. 1998 l67 DTCs P1676, P0135
MattStrike
Fri Sep 30, 2011 7:07 pm
There are no new unread posts for this topic. error
swiles
Tue Apr 06, 2010 10:02 pm
willwren View the latest post
Users browsing this forum: No registered users and 16 guests
