It is currently Thu Oct 02, 2025 2:44 pm
PostPosted: Mon Jul 05, 2010 12:20 am
Year and Trim: 1997 SE
Does anyone have any pictures in the various steps to take out the dashboard to get to the Air Mix Accuator in a 97 Bonneville?How do you get around setting off the airbag on passenger side,do you unplug it plus your battery??????I really do not know???? Aloha7/4/10
PostPosted: Mon Jul 05, 2010 8:33 am
This is for a Buick, but most of it should be the same.
viewtopic.php?f=49&t=3537
Unplugging the battery might not be a bad idea.
PostPosted: Mon Jul 05, 2010 11:26 am
:hail: Thank You I will take my time and take my dash out to get to mine in my 97 SE Bonneville .I can see it through my glovebox but that metal bar is in the way.What do I do about my airbag just dissconnect the battery?To remove the dash....7/5/10
Last edited by 97SEBonnevilleMan on Mon Jul 05, 2010 11:27 am, edited 1 time in total.
PostPosted: Tue Jul 06, 2010 1:15 am
If you are afraid of the airbag, just disconnect the battery.
PostPosted: Tue Jul 06, 2010 12:31 pm
Removed Dash "Weekend Job"
Replaced Actuator again $80.00 part was warranted through GM Dealer ,the one I replaced a year ago went bad no movement at all and replaced The Controler Box and vacume hoses $400.00 New one now tried a used one before worked for a year the AC is Back in Action Plus a recharge of the gas.....AHHHH :) /Aloha Matt
Last edited by 97SEBonnevilleMan on Fri Jul 30, 2010 10:32 pm, edited 1 time in total.
There are no new unread posts for this topic. 98' Pontiac Bonneville SE dashboard needed
wpbrink
Sun Sep 18, 2016 2:00 pm
wpbrink View the latest post
There are no new unread posts for this topic. 96-99 dashboard
xvr843
Thu Feb 24, 2011 4:13 pm
xvr843 View the latest post
There are no new unread posts for this topic. Dashboard
Jafo's Bonnie
Sun May 26, 2013 7:48 pm
Jafo's Bonnie View the latest post
There are no new unread posts for this topic. Remove Dashboard 97 SSEi
bill buttermore
Mon Jan 24, 2022 11:17 am
StraTact View the latest post
There are no new unread posts for this topic. DashBoard light not working
mmechanical
Sat Sep 19, 2009 3:50 pm
mmechanical View the latest post
