120psi oil pressure
Allmachtige
Year and Trim: 2009 G8 GT
120psi oil pressure
Post by Allmachtige »
Drove home from a friends today and the oil pressure was pegged at 120. Where do I start?
2009 G8 GT - White Hot
FMS Custom Cam, Yank 3600 SS, 1LE (ZL1) 3.91, SLP Longtubes, Magnaflow cat-back, Rotofab CAI, tuned via HPTuners
415/391
swampthing
Re: 120psi oil pressure
Post by swampthing »
umm sounds like the oil pressure sender, thats what mine did
Current fleet:
Rogue
Year and Trim: 00 Bonneville SSEi
Post by Rogue »
Yep, indicator of a bad sending unit.
Peej9089
Year and Trim: 2000 SLE Bright White
Post by Peej9089 »
Happened to me also. Common problem. Just install a new sender.
Agree w/ all above posts.
sqela
Post by sqela »
:stupid:
1994se
Post by 1994se »
When are you planning on fixing this?
http://www.thechicagogarage.org - Now Home of ILGPC
Allmachtige
Good, I was worried it was something mechanically damaging.
Do we have a techinfo on installing a new sender? Also, how much do they typical run?
415/391
bonnevillain
Post by bonnevillain »
i posted the same thread a few weeks back.. 30mm deep socket, it's on the front of the oil pan, you will see it. pretty simple job from the sounds of it (i am waiting til it warms up)
It's not physically hard, just a PITA to get at and on and off.
bill buttermore
Post by bill buttermore »
bonnevillain wrote:i posted the same thread a few weeks back.. 30mm deep socket, it's on the front of the oil pan, you will see it. pretty simple job from the sounds of it (i am waiting til it warms up)
I am not at all familiar with the 2000+, but it seems that the pressure sender would need to be in a pressure passage like the oil filter adapter plate. I would think the oil level sender might be in the side of the pan. Have these cars changed that much since '95?
1998 3.8 Dodge Caravan 214K
2000 3.3 Dodge Caravan 175K
bonnevillain
this is the location. I guess front/side/back isn't very descriptive. Some take the tire off and go through that way, others put it up on ramps/jacks and go from underneath
Allmachtige
bonnevillain wrote:this is the location. I guess front/side/back isn't very descriptive. Some take the tire off and go through that way, others put it up on ramps/jacks and go from underneath
Yikes my guess was totally off. I'll get to this next time I change the oil.
What is the part number btw? All I'm finding on rockauto.com is the oil pressure sensor connector, not the sensor itself.
415/391
Oil Pressure Switch, or it can also be called the Oil Pressure Sender or sensor. The sensor on the front of the oil pan is the oil level sensor.
You don't need to wait for an oil change, but it is most accessible from under the car.
AIRTEX Part #1S6772 $38.89
ACDELCO Part #2131650 {#12584940} Engine Oil Pressure Sensor $41.79
STANDARD MOTOR PRODUCTS Part #PS309 {WITH GAUGE} $44.99
wake
Post by wake »
just what the doctor ordered...my gf's brother has this problem with his 01 se/sle...
i thought this was it but i wasnt 100% sure..this reassures me...thanks guys :)
1994se
Post by 1994se »
If you need a garage to do this in let me know.
Allmachtige
Thanks I'll keep that in mind. First I'm budgeting the cam/headers.
415/391
woody_02silverse
Post by woody_02silverse »
Hi all, I know this is an old post but I didn't see what it would hurt to follow up, while acknowledging the prior discussion.
If the sensor is bad wouldn't it also peg with the engine off? My pressure is pegging but only with the engine running.
I know it has the right oil and the level is good. I changed the filter incase it was plugged, no effect.
It does seem like a sensor because it goes to just a tad under Max and doesn't move one bit.
Thanks.
2002 SE 123k mi.
Bosch Super Plus plugs
Alum. LIM gaskets
Dorman UIM
Replaced door watershield seals
Engine off, key off? I'd replace it, just to rule it out. If not, we can go from there.
bonnevillain
It's the sensor, it only pegs with the car on .
