my car is drafty!
bonnevillain
my car is drafty!
Post by bonnevillain »
i just noticed there is huge amounts of cold air pouring in around my drivers door handle.. has anyone else experienced this? i have had the door apart, but i dont remember exactly what the backside looks like. maybe i can just shove some type of insulation or something back there to block the air?
wake
Re: my car is drafty!
Post by wake »
this is only when the window is up right ?
bonnevillain
well if i rolled down the window i doubt i would be able to feel the little draft from the handle becuase 7* air would be pouring in through the window! :bsnicker:
wake
Post by wake »
whats im saying ryan is ive noticed on alot of my gm cars is that if you put your hand were the door handle is when the windows down you wont feel much draft but when the windows up it generally will have a good draft pouring through there
i generally dont worry about it to much cause its not that big of deal IMO...
bonnevillain
well that makes sense, the window would be in ther blocking it. its not a huge deal but it was definitely a little annoying as that's right where i rest my hand, it was getting cold! haha
Ragsdale
Year and Trim: 06
Post by Ragsdale »
All GM vehicles I've been in except for the 09 Malibu have this draft near the door handle, it's not a big deal and I've never thought to investigate.
bonnevillain
hm pretty sure my 95 didnt. i will have to pay attention in my dads impala. it just seemed like a TON of air. oh well. i will deal with it i guess
tan96ssei
Year and Trim: 1996 SSEi
Post by tan96ssei »
a thought in how to fix this remove the two nuts that hold the handle on the door and seal it with silicone sealant then as for the seals around the window heat gun and "massage" should bend them where ever you want. and the 00+ was suppose to have less problems with the seals around the body (the long rope like seal around the door sill) but those can be cleaned and also bendable by taking them off putting them in the tub submerged in hot water. plus on the bottom of the doors there are usually slits or cuts of some sort that allow water to drain. cork those and with all of that done you should effectively seal your door and heat you and leave that cold northern air out.
long story short seal exterior handle, screw holes where plastic cladding mounts, water release cuts on bottom of door, clean and bend all seals to further increase your seal do these and you should be good
Aerospace Propulsion Technician USAF
Airman First Class,
.:Michael Lyons:.
parts available on 96 see thread viewtopic.php?f=27&t=15185
Archon
Post by Archon »
Most of the door will be sealed by the water deflector. This is a picture of one for the rear door, but the front is similar.
[The extension jpg has been deactivated and can no longer be displayed.]
There has to be some openings in it for the door handle, and wiring, so any air will find its way through those. You could try some insulation to see if it lessens the intrusion. I would not suggest that you block any drain holes, or you'll end up with water problems in the door.
WhiteArrow3800
Post by WhiteArrow3800 »
I have noticed the same thing in the '01. I never felt anything in the '93.
It is rather annoying. Feels like I have the AC going sometimes. :???:
Phyrestorm
Year and Trim: 2001 SSEi
Post by Phyrestorm »
I also have this on my car, it's on both the passenger and driver door handles i can feel a very small draft of air when driving, friend of mine pointed this out to me when he was driving with me, doesn't bug me though so i don't care really, it is peculiar though.
2001 Pontiac Bonneville SSEi // NGK Iridium Sparks - Belden MAX Wires - Silverstar ULTRA Headlights - Rebuilt Transmission and Torque Converter @ 122k - New PowerSteering Pump - New Water Pump
To do LIST: LIM and Valve Cover Gaskets, Intense Shift Kit, Intense Perf. Package 1, and GXP Strut Tower Brace
bonne03ssei
Year and Trim: 2009 G8 GT
Location: Central Canadicut • ONBF_03 x2 • ONBF_04 • NEBF_06 • NEBF_07 • ONBF_07 • NEBF_08
Post by bonne03ssei »
I notice the same thing and it IS a decent amount of air...but I really only noticed after I had my driver's door replaced/fixed. So I'm thinking something someone did at the shop made it this way. Maybe there was a small draft before I just never really noticed it until afterwards.
My 94 had a similar draft too.
2003 Granite Metallic SSEi - 180,000 miles – All factory options
Essentials: rebuilt trans. w/ INTENSE shift kit | INTENSE FWI | INTENSE PCM | INTENSE drilled 180 t-stat | Aeroforce scan gauge
Goodyear Assurance TripleTreds | Energy Suspension endlinks
Exterior: cleared corners, cleared tails, red calipers, dual chrome exhaust tips
Interior: GXP steering wheel
haro1225
Year and Trim: 2004 GTO
Post by haro1225 »
I noticed that mine does that too, but only if the sunroof is in the vent position.
-Ryan
2013 Audi Allroad Quattro
yourgrandma wrote:Hi.
I've never noticed it if there is one.
