2000 - 2005 SSEi, SLE, SE Fault codes (non GXP)
Moderator: Gearheads
P0101 Mass or Volume Air Flow Circuit Range/Performance Problem
P0102 Mass or Volume Air Flow Circuit Low Input
P0103 Mass or Volume Air Flow Circuit High Input
P0107 Manifold Absolute Pressure/Barometric Pressure Circuit Low Input
P0108 Manifold Absolute Pressure/Barometric Pressure Circuit High Input
P0112 Intake Air Temperature Circuit Low Input
P0113 Intake Air Temperature Circuit High Input
P0117 Engine Coolant Temperature Circuit Low Input
P0118 Engine Coolant Temperature Circuit High Input
P0121 Throttle Position Sensor/Switch A Circuit Range/Performance Problem
P0122 Throttle Position Sensor/Switch A Circuit Low Input
P0123 Throttle Position Sensor/Switch A Circuit High Input
P0125 Insufficient Coolant Temperature for Closed Loop Fuel Control; ECT Excessive Time to Closed Loop Fuel Control
P0128 Coolant Thermostat Malfunction
P0131 O2 Sensor Circuit Low Voltage (Sensor 1)
P0132 O2 Sensor Circuit High Voltage (Sensor 1)
P0133 O2 Sensor Circuit Slow Response (Sensor 1)
P0134 O2 Sensor Circuit No Activity Detected (Sensor 1)
P0135 O2 Sensor Heater Circuit Malfunction (Sensor 1)
P0137 O2 Sensor Circuit Low Voltage (Sensor 2)
P0138 O2 Sensor Circuit High Voltage (Sensor 2)
P0140 O2 Sensor Circuit No Activity Detected (Sensor 2)
P0141 O2 Sensor Heater Circuit Malfunction (Sensor 2)
P0171 Fuel Trim too Lean
P0172 Fuel Trim too Rich
P0201 Injector Circuit Malfunction - Cylinder 1
P0202 Injector Circuit Malfunction - Cylinder 2
P0203 Injector Circuit Malfunction - Cylinder 3
P0204 Injector Circuit Malfunction - Cylinder 4
P0205 Injector Circuit Malfunction - Cylinder 5
P0206 Injector Circuit Malfunction - Cylinder 6
P0230 Fuel Pump Primary Circuit Malfunction
P0243 Supercharger Boost Sloenoid Control Circuit
P0300 Random/Multiple Cylinder Misfire Detected
P0325 Knock Sensor 1 Circuit Malfunction
P0327 Knock Sensor 1 Circuit Low Input
P0332 Knock Sensor 2 Circuit Low Input
P0336 Crankshaft Position Sensor A Circuit Range/Performance
P0341 Camshaft Position Sensor Circuit Range/Performance
P0401 Exhaust Gas Recirculation Flow Insufficient Detected
P0403 Exhaust Gas Recirculation Circuit Malfunction
P0404 Exhaust Gas Recirculation Circuit Range/Performance
P0405 Exhaust Gas Recirculation Sensor A Circuit Low
P0410 Secondary Air Injection System Malfunction
P0412 Secondary Air Injection System Switching Valve A Circuit Malfunction
P0418 Secondary Air Injection System Relay "A" Circuit Malfunction
P0420 Catalyst System Efficiency Below Threshold
P0440 Evaporative Emission Control System Malfunction
P0442 Evaporative Emission Control System Leak Detected (small leak)
P0443 Evaporative Emission Control System Purge Control Valve Circuit Malfunction
P0446 Evaporative Emission Control System Vent Control Circuit Malfunction
P0449 Evaporative Emission Control System Vent Valve/Solenoid Circuit Malfunction
P0452 Evaporative Emission Control System Pressure Sensor Low Input
P0453 Evaporative Emission Control System Pressure Sensor High Input
P0462 Fuel Level Sensor Circuit Low Input
P0463 Fuel Level Sensor Circuit High Input
P0480 Cooling Fan 1 Control Circuit Malfunction
P0481 Cooling Fan 2 Control Circuit Malfunction
P0506 Idle Control System RPM Lower Than Expected
P0507 Idle Control System RPM Higher Than Expected
P0522 Engine Oil Pressure Sensor/Switch Circuit Low Voltage
P0523 Engine Oil Pressure Sensor/Switch Circuit High Voltage
P0530 A/C Refrigerant Pressure Sensor Circuit Malfunction
P0560 System Voltage Malfunction
P0601 Control Module Read Only Memory(ROM)
P0602 Control Module Programming Error
P0620 Generator Control Circuit Malfunction
P0650 Malfunction Indicator Lamp (MIL) Control Circuit Malfunction
P1106 Dual Alternator Lower Fault/ Manifold Absolute Pressure (MAP) Sensor Circuit Intermittent High Voltage
P1107 Dual Alternator Lower Circuit Malfunction/ Manifold Absolute Pressure (MAP) Sensor Circuit Intermittent Low Voltage
P1111 Intake Air Temperature (IAT) Sensor Circuit Intermittent High Voltage
P1112 Intake Air Temperature (IAT) Sensor Circuit Intermittent Low Voltage
P1114 Engine Coolant Temperature (ECT) Sensor Circuit Intermittent Low Voltage/IAT - B Circuit Low Input
P1115 Engine Coolant Temperature (ECT) Sensor Circuit Intermittent High Voltage/IAT - B Circuit High Input
P1121 Throttle Position (TP) Sensor Circuit Intermittent High Voltage
P1122 Throttle Position (TP) Sensor Circuit Intermittent Low Voltage
P1133 HO2S Insufficient Switching Sensor 1
P1134 HO2S Transition Time Ratio Sensor 1
P1336 Crank / Cam Sensor Range / Performance
P1351 IDM Input Circuit Malfunction/ Ignition Coil Control Circuit High Voltage
P1352 Ignition Coil A Primary Circuit Malfunction
P1361 Ignition Control (IC) Circuit Low Voltage
P1362 Ignition Coil C Secondary Circuit Malfunction
P1374 Crankshaft Position (CKP)/Ignition Coil - Cylinder 4 - Early Activation Fault
P1380 Misfire Detected - Rough Road Data Not Available
P1381 Variable Cam Timing Overadvanced (Bank #1)/ Misfire Detected - No Communication with BCM
P1404 IAT - B Circuit Malfunction/ Exhaust Gas Recirculation Closed Position Performance
P1441 Evaporative Emission (EVAP) System Flow During Non-Purge Chevrolet Only
P1441 Evaporative Emission (EVAP) System Flow During Non-Purge Oldsmobile Only
P1546 Air Conditioning Clutch Relay Control Circuit
P1554 Cruise Control Feedback Circuit
P1571 Traction Control Torque Request Circuit
P1575 Extended Travel Brake Switch Circuit
P1585 Cruise Control Inhibit Output Circuit
P1602 Lost Communications With Brake/Traction Control (EBTCM) System
P1626 Theft Deterrent Fuel Enable Signal Lost
P1630 Theft Deterrent Learn Mode Active
P1631 Theft Deterrent Start Enable Signal Not Correct
P1635 5 Volt Reference Circuit
P1639 5 Volt Referrence 2 Circuit
P1689 Traction Control Delivered Torque Output Circuit
P1811 Maximum adapt and long shift (will not set the SES light and not all code readers will see this code) For more info, read here: http://www.tripleedgeperformance.com/Ha ... P1811.html
Last edited by myfirstbonnie on Wed Aug 25, 2010 9:50 pm, edited 2 times in total.
